What amp....?
#61
When I ment by pushing it, I ment if I was to buy it and I ran 600w constantly every time I'm in the car lIt's not going to overload it by trying to pull more watts then it's supposed to.
Bene you actually were to have that amp rated and it was 650w.
Alright I think I got it... tell me if I'm wrong. The amp is basically 2 2-channel amps put together in one. Every channel is 100w @ 2Ohms and when you bridge them it makes 200w. Then you x3 as a general rule because the ratings are crap and you get ~600w.
Since I wouldn't be using the other 2 channels couldn't I later on just get another sub and have two subs running at 600w?
#62
you can run 600 watts non stop and itl run fine, you cant overdue an amp
yes i did have it rated at 650 each
and yeah you got it right
but after u get an L7 you will not want another one, if anything you will want to loose bass from headaches... use the other 2 channels for your speakers to make them really loud so the bass doesnt drown it out
#63
If you had a choice between the Kicker KX600.1 and the MTX tc4004 amp which would it be? The price is about the same ..ish so don't worry about the price, I'm not worried about it.
#64
UPDATE
Installed the subs this weekend with a buddies help. I can see why a nice install cost a grip. That ish is labor intensive. Decied to say F my budget and picked up a Kicker ZX1000.0 amp. That things is pushing the crap out of those 10's. Definitely pleased. Now I gotta blow these crappy subs so I can justify buying a set of Kicker Comps or Type R's Thanks for everyones help. It was much appeciated.
#65
Nice! how long did it take you guys to wire everything up?
Edit: Dude, sorry I kinda took over your thread . I had a crap load of questions that I didn't even knew I had.
#66
#67
yeah those plastic clips dont like us at all
i hope its cooler where you are, i rewired mine in 96 degree sunlight... i gave my car a nice wash by the time i was finished
#68
Those clips are defintely the suckage. It was around 90 degrees when I did my wiring. It definitely sucked, lol. It was around 100 when I put my HU in about 3 weeks ago. Gotta love the summer and the lack of a garage.
#70
Alright lets see if I can stay on topic... . I want to power one 12" kicker L7 but not sure what amp to do that by. Bene I know you suggested the MTX TC4004 but I not going to use that other channels because the the speakers are already at their max with this new HU and I don't plan on replacing them .
I was thinking of this kenwoodand was wondering if it is any good? Its 850w @ 2ohms but I just won't crank the volume/bass to much to ruin the sub. I might even just run it at 4 ohms (500w) to see how that is and if I want more then I'll run it at 2 ohms. Is there any other good amps that are in that price/power range that I may be missing? Ohh one more thing, I want to mount the amp under the passenger seat so the amp needs to be able to stay cool and be small enough to fit underneath it.
Also what is the verdict on capacitors? Do they cure that light dimming effect? Should I need one? I've read people say that they work and others that say they are a waste of money.
#74
Originally Posted by bene
... and if you have aftermarket speakers how can they be at max?
Capacitors dont do anything only thing that will cure lights is a battery.
that amp is good for the price, but im not a big kenwood fan... whats your price limit?
BeerFest!!
#75
yeah, no many people do reviews on class AB amps cuz nobody ever buys amps for their speakers... they just want the boom amps :P
capacitor is like a lil battery, holds a charge for say 5-10 seconds... when amp demands alot of power it gives it to it instead of getting it from the battery... however as soon as it gives it, it demands the same thing back so bascially all it does is delay it for .01 of a second
