Just need a few concerns addressed...
Okay, I'm in the process of adding a subwoofer/amp setup to my gf's car with the factory HU.
I've searched through several threads and stickies here on wiring diagrams. Can anyone confirm/deny that these diagrams work for 04+ Lancer ES? I have two here...
BUT I notice that these aren't the same, which one should I be using? I know that the original diagram ( the smaller one) that has been posted has also a few posts about the colors not matching on some cars, is this because of different wiring used in the newer Lancers?
Basically, I need to know which wire to tap for the remote wire, I know the factory HU's technically don't have one but if I tap into the ignition wire will the amp turn on/off with the ignition? Or if I use the cigarette lighter, which wire is it? (I don't have a voltimeter btw)
Also, I will be using a line input converter and I would like to splice into the rear speakers. Are the wires located in the bundle by the trunk light? I couldn't see any wires coming directly from the speakers in the rear deck.
I've got the power wire ran (wow that was a pain), I've got the ground ran, and also the remote wire, now I just need to know which wire to hook the remote wire to (colorwise) and where the speaker wires are for the rear deck speakers (and which color is what).
I apologize for another thread on wiring, I noticed alot during my search but I still had a few concerned that I needed to be addressed.
if you wanted to tap the 12v cigarette lighter you could do that easy as pie--i did it to hard-wire my radar detector to my car. i don't remember which of those wires was POS and which was NEG though... i did that job a few weeks ago.
i am fairly certain that the POS on the cigarette lighter is the center post, and the NEG was the outer sleeve. it would still be worth checking with a cheap voltmeter to make sure you don't fry your amp.
darkknight
Oct 1, 2010 06:56 PM
06_RALLI///ART
26
Feb 6, 2008 06:39 AM
blaze_125
22
Jul 13, 2003 08:13 AM
