Alarm Help!!
Try turning the ignition back on and off again. You can also try pressing the lock button, then unlock button and lock button again one at a time within 2 seconds with the door open
I don't get it? so i can press the lock button then unlock and then lock over and over right after I open a door? do i open the door when the alarm is activated or when the alarm is deactivated?
Open the drivers door and do teh following with the alarm disarmed before the alarm passively arms.
Press the Lock button once
Then Press the unlock button once
Then press the lock button once more.
This must be done within 2 seconds. The alarm LED should be on solid and the remote locks will still work, the alarm just will not arm. Do the same procedure to turn of hte valet mode.
jnick
16
Jun 30, 2015 03:35 PM
