Looking for new sound system
I'm looking for a new system but don't really know a whole lot. I just want some oppinions on what subs to get, speakers, receiver, amp - pretty much everything.
I don't want to be extremely loud with my bass but I do want some nice quality sound, what brand sub do you suggest
Thanks
Thanks
memphis subs are great..if you can find them.
infinity makes great subs too.
as for components MB Quart seems to be the best quality from what ive heard. i like infinity speakers and component speakers as well.
i liek alpine headunits..they look good, sound quality is good but can be expensive, headunits aren't too different though so if u have a chance try some out yourself and choose one you like. make sure to check some features like the outputs and the wattage.
hope that helps some good luck
if you want to know good car audio setups, don't ask here. do some research. everyone is going to tell you different things. mostly people just tell you what they have and think that's the best stuff. go get some info and educate yourself otherwise you are pretty blind when it comes time to buy stuff.
only advice i can offer: don't get sony. you can find plenty of "cheaper" stuff that is still good quality. a good site to look for prices is www.etronics.com . personally, my favorites are:
eclipse head units and subs
zapco and phoenix gold amps
image dynamics speakers and subs
mb quart speakers
infinity perfect subs and speakers
boston acoustics speakers
i probably forgot a few, but that's an idea. look around, find out what makes some speakers/amps/receivers better, and make your own decisions. it'll be more fun, you'll learn more, and you'll be able to offer your own advice after it.
mb quart speakers
Cupoz yeah ur right but it takes for ever to get ur **** from etronics and its under investgation for false adverticement. So there u go i did some research. I honestly say pioneer is a very good head unit if your not getting a subs. If u are i recomend crossfire audiobahn memphis and jl and orion. but try getting the same name brand amp to run with ur sub. As for speakers inside go with MBQuarts and diamond. Nothing else for speakers they all suck *** if u want quality look bro i really now my audio took 3 classes on waves and physics to learfn resistance and so on. Two things u want for ur sub quality and make sure they can reach 2ohms with speakers 4 to 8 ohms should give u nice bass. So if u need more help Bichin2006@aol.com
For sounds system advice, there's a few questions I always like to have the answers to.
1. How much?
2. What Purpose?
3. How much space are you willing to give up?
Not knowing the answers to any of these questions, I'm just going to reccomend that you shop around. Give me some answers, and I'll do a little better.
1. How much?
2. What Purpose?
i got my headunit from etronics and had no problems whatsoever, so i can't comment on their inadequacy.
hank is 100% right, you have to know the most important thing, how much are you willing to spend.
when i was looking for my system, i knew an approximate price i wanted to spend, the components that fell in that range, and then i started looking at specific brands and trying to price match.
also, a real good tip (i think) especially if you have never done audio before, and don't know much about it, is to start small. you can always add on later, and you don't run the risk of wasting lots of money on overpriced crap.
I am acutally considering selling my stuff...
<br>
<br>
1 Eclipse 33240 Amp
<br>
<br>
310W x 2 Channel Max. Power Output at 2
<br>
200W x 2 Channel 0.1% THD at 2 Stereo, 20,000Hz@13.8V (RMS Continuous Power)
<br>
130W x 2 Channel 0.1% THD at 4 Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
<br>
ChannelFlex Crossover Adjustable Low-Pass Crossover (12dB/octave, 50-200Hz) Adjustable Pre-Out
<br>
High-Pass Crossover (12dB/octave, 50-200Hz)
<br>
Subsonic Filter (0-50Hz)
<br>
<br>
1 Eclipse 32440 Amp
<br>
<br>
200W x 4 Channel Max. Power Output at 2 Ohm Stereo
<br>
120W x 4 Channel 0.1% THD at 2 Ohm Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
<br>
85W x 4 Channel 0.1% THD at 4 Ohm Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
<br>
ChannelFlex Crossover Adjustable High-Pass Crossover (12dB/octave, 50 - 200Hz) for Front & 120Hz (Fix) for Rear Independently Adjustable Low-Pass Crossover (12dB/octave, 50 - 200Hz)
<br>
<br>
2 Eclipse 87121 DVC Subs (12")
<br>
<br>
1" Santoprene Surround
<br>
Mica-Filled Polypropylene Cone
<br>
CONEXDual Spider
<br>
Kapton Voice Coil Former
<br>
4-Layer Long-Throw Voice Coil
<br>
"Bottomless" Design
<br>
Inverted Dust Cap
<br>
Vented Pole Piece
<br>
Cast Alminum Frame
<br>
Double-Stacked Magnet
<br>
Small Sealed-Box Enclosure
<br>
Continuous Power Handling: 300W
<br>
Music Power Handling: 600W
<br>
<br>
These items were taken out of my ex-fiancees car due to money owed to me (a couple of grand). So to clear the debt I took everything she had. I'm down to these few items. I know what these items are worth since I work for an Eclipse dealer.
<br>
<br>
The first person with $750 takes it all. PM me with questions
<br>
<br>
1 Eclipse 33240 Amp
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
1 Eclipse 32440 Amp
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
CONEXDual Spider
<br>
<br>
<br>
"Bottomless" Design
<br>
Inverted Dust Cap
<br>
Vented Pole Piece
<br>
Cast Alminum Frame
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
I also have these for sale (sorry about the HTML on the pervious post)...
Alpine SPX-177A 6-1/2" Component 2-Way Speaker
Bass Engine Ready
Custom Cast Aluminum Frame
Airflow Optimized Dual-Flare Pole Vent
Integrated Spider Landing & Heat Transfer Plate
Low Loss Rubber Surround
Hemp Fiber Woofer Cone
Phase-Integrated Dustcap
26mm Soft Dome Tweeter
Ultra High Quality 2-way Crossover
On/Off Axis Compensation
Bi-Wire Input and Selectable Tweeter Attenuation
Swivel-Flush/Swivel-Surface/30¯ Angle Tweeter Mounting
Custom 17mm/16mm Adapter Plate
Retail on these is $500
Alpine SPR-694A 6" x 9" Type-R Coaxial 2-Way Speaker
120W Peak Power
50W RMS
Frequency Response: 48Hz – 30kHz
1" Soft Dome Tweeter with 15° Swivel Capability
In-Line 12dB HP Crossover with Tweeter Protection
Aluminum Coated Poly Cone
Cast Aluminum Woofer Fram
Retail on these is $350
These were SERIOUSLY used for 2 weeks before I took them out and traded my 2001 Honda Preluse Type SH in for my EVO. Unfortunately the 6x9's won't fit and I need some cash...so..
The first person with $500 get's them both!!! PM me with any questions.
Bass Engine Ready
120W Peak Power
50W RMS
Wow Hell... are all of your posts as good, well planned, and contributing to the topic as this one?
Back on topic. If you're still looking Kab, giving us a little more info will greatly affect the answers you recieve.
sure, go to an audio shop, and let them rip you off and sell you a bunch of crap you don't need and is overpriced.
or you could do some research, ask people who have experience, and not only learn for yourself but get some really good opinions.
besides, i have gone into "audio shops" many times and asked the guy there a question that he had no clue the answer. i find that most times i know more than the people selling the product.
i'd also like to add that the whole purpose of this forum is for members to share knowledge, not say "go somewhere else and ask them". what would be the point of this forum if everyone's question was answered "go to your dealer and ask them."?
SmurfZilla
May 21, 2011 09:41 AM
Slovak
15
Jul 6, 2005 09:04 AM
