What amp for Alpine type r subs...?
Old Dec 15, 2006 | 02:59 PM
xanderracing's Avatar
Hey, im thinking about getting either one, or two closed box alpine type r's.... What amp would be reccomended for 2, and what amp for only one.. Thanks.. and should i get the 2ohms or 4 ohms?
Old Dec 16, 2006 | 12:31 AM
Aight beacuse this is what i was thinking to power both of them... let me know what you think.. ive been talking to people and they say it should power them very well....
Alpine MRD-M1005
* Class D mono subwoofer car amplifier
* RMS Power Rating:
o 500 watts x 1 chan. at 4 ohms
o 1000 watts x 1 chan. at 2 ohms
* Internal, variable-speed cooling fan
* Amp Link for single-cable hookup to compatible Alpine receivers
* STAR Topology for cleaner sound
* Bass Engine® features:
o Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
o Selectable subsonic filter (off, 15Hz, or 30 Hz)
o Parametric EQ variable from 30-160 Hz, ±12 dB
o Bass Compensator enhances low-end definition
* Top-mounted digital control center with cover
* CEA-2006 Compliant
* MOSFET power supply and output stages
* Preamp outputs
* Time correction 0-10 milliseconds in 0.1ms steps
* Phase adjustment 0-180°
* Turn-on delay
* 4-gauge power and ground leads
* Extra-large terminals
* Dimensions: 13" L x 8-11/16" W x 2-5/16" H
* 90 days Sonic Electronix repair warranty
Amplifier Specifications:
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 500 watts x 1 chan.
* RMS Power (2 ohms) 1000 watts x 1 chan.
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power Not Bridgeable
* Peak Power Output 2000 watts approx.
* Min. Impedance Unbridged 2 ohms
* Min. Impedance Bridged Not Bridgeable
* THD @ Rated RMS Power N/A
* Speaker Level Inputs N/A
* Amp Preamp Outputs Yes - 1 Pair
* Built-in Crossover Yes - LP
* High-Pass Crossover N/A
* Low-Pass Crossover 30 - 200 Hz
* Subsonic Filter N/A
* Signal-to-Noise Ratio N/A
* Channel Separation N/A
* Bass Boost N/A
* Bass/Gain Remote N/A
* Fan Cooled Yes
* Fuse Rating 20A x 4
* Warranty 1-year SE
329.99
http://sonicelectronix.com/item_3732.html
~Whatcha think? i like... btw- sonic=cheapest online site BY FAR!!
Old Dec 16, 2006 | 09:32 AM
bene's Avatar
get the subs at 2 ohms... and that amp is good but you dont have to spend that much if u dont want to
Old Dec 16, 2006 | 10:06 AM
Matthew333's Avatar
I would run a high current amp, with one 2 ohm sub. (dual 4 ohm) Putting another sub in will only net you 3 to 6 db more at best on the low end. You could run a 2 channel mixed mono, or a 5 channel to the entire system (amplify the high end also)
Old Dec 16, 2006 | 10:43 AM
Never Satisfied's Avatar
Alpine MRD-M605 if only using one sub. Get the dual 4 ohm, wire it for 2 ohms and you will be getting the most out of that setup.
Alpine MRD-M1005 if using two subs. Get the dual 2 ohm, wire them for 4 ohms each, and then wire back to 2 ohms at the amp.
BUT... you don't have to use an Alpine amp with them if you can't swing that much cash. Just look for something with similar specs and you should be alright. Kenwood makes some good amps, as do JL Audio, Clarion, Memphis, Digital Audio (I've heard good things, no personal experience), and quite a few others.
Old Dec 16, 2006 | 04:16 PM
bene's Avatar
i dont recommend the all in one amp system, thats to much for amps and they overheat alot
Old Dec 17, 2006 | 01:40 AM
all in one as?.. 5 channel? im just getting mono... but thanks for the good posts so far.
Old Dec 17, 2006 | 11:49 AM
bene's Avatar
when you get it too make sure you set it up right so your not getting more voice from your subs than you are from your speakers :P
Old Dec 23, 2006 | 08:51 AM
iyi0521's Avatar
Yeah make sure you properly adjust your crossover.
Memphis MCD1000 Get a pair of dual 4ohm subs and wire em for a single 1 ohm load.
Old Jan 5, 2007 | 02:00 PM
silverES's Avatar
I had an MTX thunder801d mono bolck amp on a 12" DVC Type R. I forget the OHM load I was running, but it pounded hard
lanceritis
16
Jun 12, 2008 10:23 PM
JordanS4
Jul 30, 2007 04:14 PM
ImJoey
Jun 27, 2007 05:05 PM
flatlandjuggalo
Nov 23, 2006 08:08 AM
pumpdog720
Sep 7, 2005 08:05 PM
Quick Reply: What amp for Alpine type r subs...?
