no sub preout???
no sub preout???
i got a deck without a sub pre out, what is the best way to connect an amplifier and sub to this deck. it has three preouts on the back. they are labelled front, rear and aux input.
the deck is http://www.cardomain.com/item/CLADXZ665MP?vq_id=none
the amp is http://www.cardomain.com/item/CLAAPX1300
thanks for the help.
Well, assuming you only have the sub amp right now, you can just use the signal from either the front or rear preouts on the hu. Then when you get a 4-channel for your speakers, use the 4-ch amp's pre-outs for signal to run the sub amp... Hope that helps!
y not? mono means one channel. A class A/B amp sounds better but is less efficient. Most high end mono amps still use the A/B class rather than degrading to the class D. Just take a look at the Phoenix Gold Titanium series even the 1200.1 was class A/B (http://phoenixgold.com/2004/titaniumamps.html)
Nevaeh
Mar 18, 2011 04:41 PM
