Damn Rear-View Mirror Rattles Too Much!!!
Old May 27, 2003 | 03:17 PM
Zeeshan's Avatar
i put in my system a month back and things were great. but now im noticing that the rear view mirror is starting to rattle way too damn much. anything to keep it still, any kind of reinforcements i can get?
thanks,
Zeeshan
Old May 27, 2003 | 03:36 PM
OPIE112's Avatar
3m mounting tape should do it. Its the foamy looking tape!
Old May 27, 2003 | 03:38 PM
Zeeshan's Avatar
cool, where exactly should i put the tape?
Old May 27, 2003 | 03:52 PM
RobertK's Avatar
I have this same problem.
a lil more detail on where to put it would be great.
Old May 27, 2003 | 04:45 PM
Higgity Hank's Avatar
I think Opie was talking about if you should happen to lose your mirror, which I'm not sure either of you has.
Which joint on the mirror assembly is loose? Where the arm meets the windshield bracket, or where it meets the mirror itself?
Old May 27, 2003 | 07:46 PM
cupOZnj's Avatar
how about turning the volume down.
my buddy had 10 JL12w3s in his aerostar, 1000watts, sure everything rattled, and the mirror shook, but that's what happens when every air molecule in the car is vibrating at maximum force...
Old May 28, 2003 | 02:04 AM
Zeeshan's Avatar
thats all fine and well, i had a system before in my eclipse and the mirror didnt rattle AS MUCH because it was like real stiff. might be because it had the reading lights built in so it was sturdier cuz there was wires and stuff running to it, but i dont know. just wondering if something out there will hold it a bit more still, not completely stop it from vibrating, cuz i know thats impossible. just a little sturdier.
Old May 28, 2003 | 05:04 PM
Hellacious's Avatar
No clue...just turn down the damn music
Old May 28, 2003 | 06:51 PM
cupOZnj's Avatar
in that case, i guess you have a couple options:
A. get a new mirror that seems sturdier and secure it with something that will hold better than the stock setup.
B. fasten the stock mirror with something, fashion up a support brace or tie some wire around it attached to another point.
C. take the mirror off....
D. live with it
Old May 29, 2003 | 03:03 PM
Joka's Avatar
Its going to happen, i have 2 jl 12 w7's...my mirror fell off
Old May 29, 2003 | 03:24 PM
RobertK's Avatar
damn dood. I just checked your registry.
I have 1 10w7 with a 1000 watt amp.
I wanna go 2 of them... but I want another 1000 amp for the second as well.
hows that alternator work for ya?
initialg86
Lancer Troubleshooting
Dec 23, 2011 07:42 PM
redbeard
May 17, 2004 05:57 PM
Zeeshan
Mar 11, 2004 10:17 PM
Zeeshan
May 12, 2003 02:35 PM
NeX
44
Feb 26, 2003 05:30 PM
