New System. Almost finished, but have a few questions
So this is what my problem is. I can't remember where which goes which. I tried doing the how-to, but I got too confused since I'm almost done
Here are pictures of my AMP, and the wires all ready. And the Subs SHOULD be a piece of cake. I want to finish something by myself lol.
POWER: Blue and Silver
Then a thin baby blue cable
Then the White and Black connectors (RCA)
For the Subs, it's just speaker cables going from the SUB box to the AMP, but where? Bridget?
p.s. Yes, this is my first time doing a system install
VIDEOS:
AMP:
WIRES:
VIDEOS:
AMP:
WIRES:
The thin baby blue wire is the wire you use so the amp will turn of when you turn your car off. The black is the ground. For the subs you should bridge them for max power. So both positives wires go on one and both negative wires go on the other. It says on the amp where to connect if you want to bridge. Hope this helps a bit
DAMN I did the one in my Lancer. But I'm trying to do the same in my new car, and I can't figure it out. It's already pre-wired, I just need to connect them, and for some reason, ALL of my knowledge has vanished!
It just looks so easy. I guess I'm getting old. Loosing memory these days...
I'm going to try again. Forgot I have a CAP, but not sure if I want to connect it
TTP Engineering
Nov 27, 2007 08:02 PM
DTM_Berty
31
May 19, 2007 04:33 AM
