Simple alarm diagram
CONSTANT: White wire found at the ignition switch harness
IGNITION: Black/White wire found at the ignition switch harness
STARTER: Black/Yellow wire found at the ignition switch harness
DOME LIGHT: White (-) wire found at the white plug bottom of fuse box
TRUNK PIN SWITCH: Green/Orange wire at the trunk light
PARKIING LAMPS: Green/White (+) wire found at white plug bottom of fuse box
POWER LOCK: Yellow wire Found behind drivers side kick panel (negative pulse)
POWER UNLOCK: Gray wire found at white plug bottom of fuse box
HORN: Blue/Red (-) wire found at ignition harness
TACH SIGNAL: Orange wire found at ignitor #1 cylinder or at the under hood relay box labeled "Engine Speed Detection"
IGNITION #2: Blue/Black wire found at the ignition harness
ACCESSORY: Blue/White wire found at ignition switch harness
BRAKE LIGHT: Green (+) wire found at switch above brake pedal or black plug in drivers kick panel.
REVERSE LIGHT: Brown (+) wire found at 25 pin found on drivers side console
I hope this helps you out. Let me know if you need anymore help.
I use them. But you must make sure that it makes a good contact. I strip away some of the wire, then place the tap on the wire. I then solder it. I'm a little **** when it comes to connections.
How do I wire up the door locks? I see the power lock you listed says it's a negative pulse, does that mean the unlock is a positive? The alarm wiring has a wire that is (-) Lock, (+)Unlock and another for (+)Lock, (-)Unlock. Which goes to which? Also, do you know if the 06 Lancer requires a second starter output for the remote start feature?
You only have 1 starter, but 2 ignitions.
Dreamrunner18
Jul 29, 2017 01:52 PM
mauisurf2003
Feb 20, 2007 09:56 AM
