Amps
Amps
I'm wanting to get a new amp:
Alpine MRD-M500
900W MAX Power
500W x 1 (2ohm 14.4V)
V12 AccuClass-D Design
Digital Control Center with LED Display
Bass Engineฎ DSP:
- Parametric EQ
- Crossover
- Time Correction
- Subsonic Filter
- Phase Control
- Bass Compensator
Remote Bass Knob or Remote Amplifier Control Center (RACC) ready
STAR Topology
4 Volt Input Capability
Integrated Wire and Screw Down Terminals
Variable Turn-on Delay
Safe Mode
OR
Phoenix Gold R5.0:1
High efficiency Class "D" monoblock amplifier
500W x 1(2 ohm Mono)
18dB LP variable crossover
Low Pass Level port (LPL)
Dimensions: 12.675L x 10.875W x 2.25H
Alpine MRD-M500
900W MAX Power
Bass Engineฎ DSP:
- Parametric EQ
- Crossover
- Time Correction
- Subsonic Filter
- Phase Control
- Bass Compensator
STAR Topology
Safe Mode
OR
Phoenix Gold R5.0:1
That's really a 6 of one, half dozen of the other choice... They're both nice amps with good features, made by respectable companies. In that situation it really comes down to price and looks since they share similar features.
My choice would be with the Alpine of these 2. Simply because I've not known anyone that's ever used the Octane R series, and I don't care for the look of them that much. PG makes quality products though, so I don't doubt the amp.
It's really a coin toss.
Originally posted by RobertK
the pg is actually more expensive for once.
As for other suggestiosn if you only care about power, the JBL BP600.1 will push whatever you've got all week. If you need things like a subsonic filter, bass EQ, bells and whistles (similar to what oth of these amps have) it's not the amp you want.
It really depends what you're looking for, and what you've got to spend. I suggest you check out some of the following brands:
Hifonics
Orion
PPI
Zapco
Soundstream
JL
JBL
MMATS
Memphis
Xtant
MTX
Kicker
Autotek
Concept
Tsunami
Avionixx
Resonant Engineering
That list should basically cover all price points, and many many styles. I've personally installed amps from 3/4 of these manufacturers and never had a problem with any of them (the other 1/4 are products friends use and haven't had problems)
At least it's enough to get you started.
US Acoustics makes some pretty solid amps. I can't believe they didn't make the list, a friend of mine uses 4 of their amps in his truck... (that's what I get for writing a list off the top of my head)
Englando
54
Jun 1, 2014 09:12 PM
93civEJ1
Jan 30, 2008 11:32 PM
davids2004
South Region
May 22, 2005 06:47 PM
