Remote Start On 5 Speed
that is incorrect. In order to start the car you have to get out in a way that the alarm knows it is not in gear. and if you disarm the alarm or it is triggered it will not start.
any remote start should work...there should be a switch behind your clutch pedal, remove the clip and you should than be able to start your car with just turning the key and not pressing in the clutch...
essentially all you are doin is hookin up the remote start like any autimatic car now and it will work......if you want to get into "safety precausions" than yes find a kit that checks if its in gear, and is e brake pulled up and all that bs...
but if you are like me and never keep car in gear, you have nothing to worry about.
there is a little sensor right behind the clutch pedal not hard to miss it un clips in 2 secs if not buy a manual tranny starter and boo hoo you need to wire in a relay.......when it comes down to it though imo before you leave your car you should check what state it is in i.e. in gear or e-brake......you are leaving a big pile of money sitting there essentialy and if it was me leaving a big pile of money on the street i would make sure it is safe and not about to roll away or take off lol
I got mine at a place in Durango, CO... Compustar makes them for manuals, and it only habit now to leave it in nutueral and pull the E-brake or it wont turn the turbo timer thats on the system on....very nice for Hot summer days or cold winter nights...
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
I have an Audiovox remote start/alarm system for an automatic and when installing it we just got rid of the clutch pedal sensor. Yes if left in gear the car will jump but why would I leave it in gear knowing that...? IDK about going through a shop since my friend installed mine.
I installed the compustar myself and a DIY will defeat the purpose of the alarm. the remote start in the compustar doesn't need sensors or switches to detect that you are not in gear. It will not start if you are in gear period! Because of their "reservation" mode, that means the engine is running when you pull out the keys and lock the car(either as a turbotimer or remote start mode) will indicate that the car is not in gear. search is your friend in this site.
I use the viper 5900 in my 5 spd. For those of you that aren't familiar, it is more or less the same as the viper 791xv with improved range (1 mile is advertised). However neither one is manufactured for use on manual trans. I'm just one of those people that always leaves my car in neutral.
The 5900 uses sst technology and like the 791 has the lcd display. With vipers new model (the 5202 i believe, correct me if i'm wrong) the responder le technology has an advertised range of about 2000' and is designed for auto/manual. Also, instead of the lcd, they use "ghost light" leds and it also display climate comfort level (even tho there are other brands that will show you exact temp this one just lights up 1 to 5 leds to tell you how warm the interior of the vehicle is.)
whoo, now i'm winded....so
to sum it up, if you dont want to have to remember to leave your car in neutral, go with one designed for a manual cuz it will require that you put it in neutral to remote start. if you just dont care, bypass the clutch and pretend its an auto.
hope this helps
What exactly are you looking for? like step-by-step with pictures? install will vary depending on what product you are putting in. I can post the wire colors/locations if you want.
and don't get me wrong, i'm all about the diy, but if you are not familiar with this kind of stuff i would recommed either having a KNOWLEDGABLE friend help or just get it done professionally.
i'll be of any help i can tho.
The reason most shops won't do this sort of thing is for the simple fact it is illegal in most states due to inspection reasons. My friend got one installed in Jersey and when he had to get his car inspected by the state they failed him due to the remote start. They said it was for safety reasons. However you can find some shops that will do it only cause it gives them business.
