how do you remove fuse 22 and 23?
my neighbor has a yellow boosted 02 lancer oz. he wired 3 gauges to his cd player power wire and all of a sudden his clock and cd player turned off all of a sudden. is it the fuse?
im guess its number 23 under the hood where the cd player is located. how do you remove it though because it has yellow brackets supporting it. i dont want to break it, thanks
easiest way is to take out the green top ecu. then you got access to the side of the yellow connector. You can see it's being held by a clip on either side. stick a small pick or screw driver in it and pop it out.
you can insert your new fuses directly into the fuse box WITHOUT the yellow thing. it'll be easier to replace the next time. I really don't understand why they have that on there.
Enkrypter_DJ
Lancer How Tos / Installations
Jul 30, 2007 04:27 PM
