Installed Aftermarket CD player, Instument Panel Light now working!!!
Hello All,
I just installed a JVC aftermarket Cd player. Now my intsrument panel, hvac and cigarette lighter (LIGHTS ONLY) do not work. THEY FUNCTION BUT THE LIGHTS DO NOT WORK. I followed the instructions provided to the point. Ive also checked all of the fuses. Fuse # 20 keeps on failing on me. Any suggestions?
sounds like a short somewhere maybe?
you prolly bumped a wire and loosened the connection to the lights check all the connections..if you dont know what your doing really you might be better off taking it somewhere before something gets worse
and what kind of car is this?
Go back in and disconnect the illumination/dimmer wire (usually orange) from your stereo harness that you wired up. This wire is not needed to install the stereo and 90% of the time will cause the fuse to blow. As for the fuse, you will have to look in the fuse panel and replace the blown one, it should be a 10 amp and say something about illumination or instrument cluster.
Since I don't know for sure what year we are dealing with, I can't give you more exact instructions.
Not a problem.
Like I said, 90% of the cars I have worked on will blow the fuse if you hook up the illumination wire straight. I've worked on anything from Geo Metros to Porsches to classic cars like a 56 Bel Air.
henry22
Jul 1, 2014 09:23 PM
mirage 4g93t
Mar 12, 2008 06:03 AM
ebbeast2005
13
Feb 19, 2004 07:47 AM
aftermarket, blow, cd, dimmer, dont, illumination, installed, instrument, light, lights, panel, player, stereo, switch, work
