12v power source
Old Aug 21, 2003 | 02:23 PM
HobieKopek's Avatar
12v power source
So...I'm reinstalling my gauges because my EGT was never properly wired amongst other things. I checked my wiring and everything works on a direct 12v source, but I'm looking for a 12v source that turns on/off with the parking/headlights so that I don't have to run my gauge lights off a switch. Could anyone please help me out here? If you have a pic that'd be awesome, if you have a verbal description, that should be just fine too. Once again I have managed to render my car temporarily undrivable. ...
Old Aug 21, 2003 | 02:25 PM
rockfu's Avatar
hit up the dimmer switch power before it gets to the dimmer switch, would that work?
Old Aug 21, 2003 | 02:27 PM
HobieKopek's Avatar
Guess I could try it. Long story short I'm locked out of my car right now and looking for ideas. I already need to tap something else into the dimmer though...was wondering if anyone knew the location of the parking/headlights power source though.
Old Aug 21, 2003 | 02:29 PM
rockfu's Avatar
that was my first idea but I have NO clue where the wires are for thos... maybe just follow some wires from the steering collumn and use a voltage tester.
you're locked out of your car and this is your main priority??
you are a much more relaxed person than I
Old Aug 21, 2003 | 03:23 PM
HobieKopek's Avatar
My good friend's a locksmith. Once he gets back from a lockout he'll have me back in the car in no time. Looks like I'm playin' with the multi meter.
Old Aug 21, 2003 | 03:28 PM
rockfu's Avatar
I use to be able to break into my old car in about 30 seconds. I'm glad I've never had to try it in the lancer yet (knock on wood).
I just had another idea.... could just go directly to the head lights, and find the power wire there that turns on with the switch... but I think thats taking the wiring to an extreme, and ou'd have to run the wires all the way back inside.
Old Aug 21, 2003 | 03:29 PM
HobieKopek's Avatar
I'd like to stay on one side of the firewall, thanks.
Old Aug 21, 2003 | 03:33 PM
ExoByte's Avatar
You can tap into the fuse box for this:
http://www.jonesland.com/evo/BoostGauge_Install.htm
Old Aug 21, 2003 | 03:34 PM
HobieKopek's Avatar
Thanks ya muchly.
Old Aug 21, 2003 | 05:09 PM
SICKdimension's Avatar
does this go for anything with 12v power?
Old Aug 21, 2003 | 05:12 PM
HobieKopek's Avatar
Ended up using a green wire with white stripe that comes from the dimmer and also is switched along with the lights. Thanks all.
picco97
May 3, 2016 10:54 PM
Inprogress
Jul 29, 2008 05:14 PM
tephra
Mar 22, 2008 02:58 AM
phil_
Oct 25, 2006 07:32 AM
red evo8
Feb 1, 2006 12:26 PM
Quick Reply: 12v power source
