Fuses with a constant-on all the time?
Just seeing if anyone knows of one of the fuses under the dash that has a fulltime constant power? The ones i've been tapping into only work with the key in the on position.
I see you have a 08 lancer...I have a 06 evo. I'm assuming the ignition harness is similar. Try the thick white wire in the ignition harness on the steering column. I could be wrong since i've never been in an 08.
But anyway, if there's no white wire, get a voltmeter and try all the wires on the ignition harness. There should be a constant 12+ there.
GL
GL
GL
GL
but either way, use a multimeter to test it
llDemonll
Pacific Northwest
11
May 22, 2012 02:35 PM
wmcorcor
Jun 3, 2009 10:58 AM
czapski
Nov 26, 2008 08:01 PM
ali911
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jun 11, 2007 07:47 PM
