What kind of amp would be needed to power two of these?
http://mobile.jlaudio.com/products_subs.php?series_id=4
they're 400rms... DVC 4ohm
Also how would I wire it up from the amp? Would I need a cap for it?
As far as the wiring goes you can run it in either series or parallel. Here is an example of how each would be done with a single subwoofer. http://www.the12volt.com/caraudio/wo...s.asp?Q=1&I=42
If you run two of these subs with with the 500/1 you would have to run them in series/parallel. On this second link you want the bottom wiring diagram, not the top as the jl amp can only go down to 1.5 ohms. http://www.the12volt.com/caraudio/wo...s.asp?Q=2&I=42
Oh and one more thing, if I wire them per the second diagram, at a 4 ohm load, would it be 500wrms to each speakers? or 250rms to each speaker?
since they are both dual 4 ohm, they can be wired at the amp down to 1 ohm together. find an amp that is 1 x 1000 watts RMS @ 1 ohm, 1 channel, 1000 watts, 1 ohm stable.....i recommend Hifonics amps....very powerful and good quality and low price! you could get the BXi 1210D for those subs and they would sound awesome.
http://www.sundownaudio.com/index.ph...saz-1000d.html
could you please go into more detail? how would wiring a 4ohm speaker down to 1 ohm be good for the speaker? How does Hifonics do in handling crossover, and sound filtering? I am going to be using a RCA out for the subs.. with the subs wired down to 1ohm on this amp, what would be the constant wattage they're getting?
I disagree with this statement. These subs are not meant to run down to 1ohm. Thats not my opinion that is a fact stated by a JL audio rep. Also as far as running the w6v2 with a 1000watts rms that is just asking for trouble. These subs are not like the w7 you had, they will eventually blow running at that low of an ohm/wattage. While the Hifonics are a nice entry level amp, I would suggest spending a bit more money and get something mid range. Sundown Audio makes some amazing amps and they are very reasonable priced. I suggest picking up the saz-1000d. They are on sale right now for $275 plus shipping. At 2ohms the amp can push out 600watts rms. This would still be in the safe zone for these subs.
also, I did not have W7s, I had Kicker L7s....louder and cheaper, got 2 brand new for $368 shipped running on a Hifonics 1600 watt amp for $200 shipped with a custom made ported box. made a 135.7. want the video?
Nevaeh, listen to whoever you want, but now you have my side of the info. good luck!
would that be 1200/rms to each sub or 600rms to each sub??
Originally Posted by JL Audio Support Desk
2 DVC drivers with Voice Coils in Parallel / Parallel
Connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedance's:
Dual-6 Ohm Subwoofers: 1.5 Ohms
Dual-4 Ohm Subwoofers: 1 Ohm
Dual-2 Ohm Subwoofers: 0.5 Ohm
Dual-1.5 Ohm Subwoofer: 0.38 Ohms
2 DVC drivers with Voice Coils in Series / Parallel
Connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedance's:
Dual-6 Ohm Subwoofers: 6 Ohms
Dual-4 Ohm Subwoofer: 4 Ohms
Dual-2 Ohm Subwoofer: 2 Ohms
Dual-1.5 Ohm Subwoofer: 1.5 Ohms
it would be 1200 RMS total divided by the number of subs that are connected to it. so yes, 600 RMS per sub.
and yes thats exactly the thing I was referring to
Here is a photo of the driver from behind... as you can see there are essentially 6 posts... how do you wire it up with these posts, that can be seen in the photo? per the parallel
I've never heard anyone say a speaker would care what ohm/resistance it was set up at. That is the whole point of DVC speaker, IMO, to give you flexibility with your installs. Your amp will surely care, and most cheap to even moderately expensive amps aren't 1 ohm stable. That's going to be pushing your equipment pretty hard. I think I would have to do one amp per speaker and show each a 2ohm load and try to give each woofer at least 500 watts RMS.
