CEL and rough idle
CEL and rough idle
I've had my piggy back for about a week now and so far it has been wonderful in terms of gains but the idle and CEL are bothering me. I know if I can fix the idle I can fix the CEL. SO with that....
What is causing the misfire at idle that i making it run so ruough? I would like to tune the car more but I am afraid that it might make it worse or even possibly make me lose performance. if anyone has any ideas or input, it would all be greatly appreciated.
BTW I have an 03 automatic.
-Justin
-Justin
i have the rrm piggy version 2. Im guessing you have the same one. anyways the misfiring is actually from the delay in the signal that is caused by the processors in the piggy. The cel goes on when the ecu picks up sporatic idle or if the idle drops too low.
The solution to the rough idle is other map that rrm can provide you. There are TWO maps that i currently know of. The rough idle=power comes on quicker and the smoother idle= power comes on about 500 rpm later.
Paging zlancer.....
Paging zlancer.....
Domengg Domino
Dec 3, 2016 07:06 PM
VtexGt3
22
Oct 9, 2016 08:11 AM
abevAWD
Jun 4, 2015 06:32 AM
EvoTeyn
11
Apr 19, 2011 03:12 PM
