Stock injectors?
I'd be a lot more worried about EM than injectors if you're getting the RIPP tuner kit...
You have choices, if you know where to look. WRX injectors can be used. I think some DSM ones as well. Search around enough and you'll find choices. Also, it couldn't hurt to ask HobieKopek, as he's our boost guru.
235cc. All this information is readily available if you look for it however.
Your kit will be worthless without fuel management, so I'd worry about that a lot more. Injectors are secondary to engine management in this case, and, assuming you're planning on using a piggyback for fuel tuning, you may find certain ones are limited as to what size injector upgrades they can control. Good luck. You'll probably need it. IMO, the fuzzy logic "Black Box" was the best part of that kit, and it's the only thing you're not getting.
EDIT: DSM injectors are low impedence and will require resistor packs in order to function properly without risking damage to the ECU.
FS[SouthEast]: Evo 9 stock injectors
hutch959
Sep 12, 2016 06:16 PM
fromgsx2evo8
May 16, 2005 08:34 AM
