Free tune ... anyone interested?
Funny you should say that, I ordered some stiff motor mounts from RR last week. I'm not sure if it will arrive in time for me to install them before the tune. I'm getting bad engine shudder under hard shifting and acceleration.
Hopefully it won't mess up the tune very much.
I can't talk about prices, but maybe some vendors on the site could help you with that. Many vendors offer tunes for the Evo for around $150 (if you have the cable used to flash the car). I would think a tune for the Lancer would be a little less since it's not boosted.
That's what this test is about ... many people don't feel that the tune is useful. I honestly feel that a proper tune could give you more power and help extend the life of the engine (in the case of the Lancer).
"Tuning" means modifying the data in the car's computer, or ECU. This can change the fuel mix, spark timing and other things that affect the vehicle's performance. Some vendors offer this service remotely and can e-mail you files to upload to the vehicle's ECU. You simply need the cable and software to connect to the vehicle.
We did the testing Saturday. Some things came up Sunday and I didn't have time to write up the results. I'll post them within the next few days.
Cliffs:
It was hot as hell.
Car was knocking at cruise. Not enough to degrade the octane value, but enough that I'd personally worry about it.
The mods on the vehicle didn't throw off the factory settings/calibration much at all. fuel trims were not perfect, but acceptable.
AFR's on the stock tune were quite rich, but that's by design.
Aimed for a 12:1 AFR. Cat converter caused some variance in readings at the tailpipe depending on temp.
We didn't see notable gains on 87 octane at 12:1. I think we could get a little more power at 11.5:1 or so, but we ran out of time for testing.
It continued to be hot as hell.
We did find gains on 93 octane at the same 12.0:1 AFR, but still nothing extremely notable. Again, I think more could be found at a slightly richer AFR but we didn't test that.
At the end of the day, Brian left with the tuned 87 octane map. Not much in terms of power gain, but detonation at cruise should be gone and AFRs at high throttle are much better and that should yield better mileage for drivers with a heavy foot.
Cliffs:
It was hot as hell.
