trouble with 1.3 tactrix cable
Old Aug 22, 2009, 03:59 PM
bluelancer20028's Avatar
thanks for the info
Old Aug 28, 2009, 06:17 PM
v1.29a did the same thing and i have to wait til after the first to get unlocker b/c its in RAR compression. If anyone has that unlocker without it being compressed or winzip or something let me know
Old Aug 28, 2009, 06:49 PM
senate6268's Avatar
WinRAR has a 30-day trial for their program:
http://www.rarlab.com/download.htm
Old Aug 29, 2009, 11:47 AM
does the unlocker have to be with v1.29a or can it paired with 1.42 b/c i tired 1.42 and same thing happened so im at the point that this certain cable sucks
Old Aug 29, 2009, 11:59 AM
03lances's Avatar
Wow I hope I dont have this much trouble when I start flashing my rom that sucks man. All I have done since getting my cable is pulled my rom and done tons of datalogging. Not gonna start flashing till my turbo goes in
Old Aug 29, 2009, 08:09 PM
senate6268's Avatar
What I would suggest is pull your stock ROM and write your stock ROM back to your ECU to ensure you have full functionality before you begin tuning.
Old Aug 29, 2009, 08:13 PM
senate6268's Avatar
It is possible that your cable has an issue. On AktiveMatrix there is a comment that the unlocker has been tested with EcuFlash v1.31 and earlier. You might want to give v1.29 a try and see what happens.
Old Aug 29, 2009, 08:49 PM
I downloaded v1.29a. Im gonna try again in the morning to flash ecu. Senate why does the maps for my rom change so much when i went to v1.29a from v1.42??? Its kinda like it was before kinda all jumbled up like before.
Old Aug 30, 2009, 09:28 AM
senate6268's Avatar
It's because after v1.29a, EcuFlash changed the way it interprets the endian values of the ROM. I'd actually like to get everyone on the newest version of EcuFlash and permanently change the definition files to reflect that.
Old Aug 30, 2009, 10:18 AM
ClixT's Avatar
so how can we change the def files to suite the latest ecuflash?
Old Aug 30, 2009, 12:24 PM
senate6268's Avatar
After v1.29a, all the endian values were interpretted as "big" and not "little". With v1.29a and before, they were mixed. So if you open your ROM in a newer version of EcuFlash, the table data will look right, but the axis values will be jibberish. With the table open, you would go to Edit > Edit Map Definition. Then you would click the Scalings button and change the scaling (fuel tables use Load and RPM) for each axis. When the Scaling Manager opens up, find the axis in the list (Load and RPM for fuel tables) and click Edit. Then change the data endian value to "big". Now you will see the axis values showing up correctly. You will need to do this for Metadata of each table.
Old Aug 30, 2009, 08:58 PM
ClixT's Avatar
thnx senate
Old Jun 6, 2010, 01:27 PM
fbikawi's Avatar
i have the same problem of the original thread composer.
tried the unlocker. no good.
tried 1.3 and 2.0 cables no good.
tried 1.29 and 1.40 no good.
dont know what to do?
read is ok but write gives the error message!
mymigi
Jul 25, 2019 03:34 AM
Falcon_2003
Jul 1, 2016 07:35 AM
Panky
Jun 9, 2015 06:20 AM
RanEvo
Feb 5, 2013 07:07 PM
rivalaC
Jun 13, 2008 09:35 AM
Quick Reply: trouble with 1.3 tactrix cable
