Will an enlarged throttle body mess with the tune too much??
Old Feb 5, 2010 | 12:33 PM
yitzac1990's Avatar
Question Will an enlarged throttle body mess with the tune too much??
Im thinking of getting my throttle body enlarged with a bigger butterfly valve too of course, and just wondering if the increase in air will mess up the tune too much, or if it will be fine with a slight power increase?
Old Feb 5, 2010 | 03:28 PM
ambystom01's Avatar
Yes, get it tuned. While the MAF is metering all the air that passes it, with the stock fuel delivery, it's anticipating that X amount of air will enter the intake manifold and combustion chamber. With the bored TB, more than X can pass through it, into the intake manifold and into the engine. While a tune may not be absolutely critical, it's worth checking the AF values to see if there's any change and to compensate for those changes.
Old Feb 5, 2010 | 09:59 PM
TopTuner's Avatar
yupp what he said if it is a piggy tune then a re tune wont do much if anything. if it is a reflash with set values not a altered code(piggy) then you should tune it. it will do fine without the tune but if you can retune it for the enlarged throttle body it will help. how big you plan on going?
Old Feb 6, 2010 | 01:06 AM
yitzac1990's Avatar
well wouldnt the MAF make up for the extra air by just adding a little more fuel? i dont know what size exactly, I found a guy local to me that does them "as big as possible, yet maintaining structural rigidity" etc. etc. haha
Old Feb 6, 2010 | 11:53 AM
mines hotter's Avatar
boomba racing has throttle bodies for the x and they said it will work with our cars you just need a coupling and they will custom make a bracket to mount correctly and everything a little pricey though
Old Feb 7, 2010 | 03:15 AM
Bawb3's Avatar
Yeah, its a lot cheaper to have the stock TB ported.
And yeah I'd recommend a tune, but you have a wideband right? Just make sure the afr isnt getting too lean.
Old Feb 7, 2010 | 05:57 AM
yitzac1990's Avatar
well Im getting a wideband soon anyways, so I guess ill wait until I get that before I port the TB lol
Erik@MIL.SPEC
365
Aug 29, 2017 01:59 PM
Rom
Feb 21, 2017 12:48 AM
Boomba Racing
EvoX 'For Sale' External Engine / Power
39
Nov 24, 2015 12:32 PM
Boomba Racing
19
Dec 6, 2009 04:10 PM
rhyzin
Lancer Engine Tech
17
Apr 19, 2002 07:47 PM
Quick Reply: Will an enlarged throttle body mess with the tune too much??
