ECUflash/ Tactrix cable newb thread
Now, after saying all that, the only obdII cable to usb that says it supports mitsubishi that i can find is the tactrix cable....but obdII is a standard, so i guess it depends of the amount of data that's supposed to be supported. can you link to anything that you might be talking about, like some sort of standard usb cable?
![](http://img185.imageshack.us/img185/7630/reflashtactrix.jpg)
I tried version 1.42 and it wouldnt load, but then again i also didnt have the reflash connector connected so that could have been why. But right now im using version 1.29.
Is mitsulogger free? or should i buy Evoscan? What do you guys prefer?
So i went to this URL to download mitsulogger but it wont work http://www.aktivematrix.com/forum/dl...ile&file_id=35 It keeps saying "upgrading site.." or something like that. Is there anyone that has an actual file or something that i could use to download mitsulogger?
damn...thanks senate but i just bought evoscan anyways. So here is my first run going into boost...dont look too good..
TPS: 42%
RPM: 2,593------hard acceleration from zero until this RPM
COOLANT TEMP: 210
BATTERY LEVEL: 13.9V
AIR TEMP: 82.4 DEGREES
TIMING ADVANCE: 7
IPW: 13.312
IDC: 28.7
LTFT LOW:6.0
LTFT MID: 7.6
LTFT HIGH: 0-----------not sure why this is zero???
STFT (02 SENSOR) 24.80----------im pretty sure thats not suppost to be that high?!?
ARF: 12.4
AIRFLOW HERTZ: 431
02 SENSOR: 0.4V
MPH: 32
FUEL CONSUMPTION: 3.4 MPG LOLOL!
AIR VOLUME: 184
KNOCK SUM: 10 :-(
KNOCK VOLTAGE: 0.7V
OCTANE LEVEL: 100%
ECU LOAD: 88.125
INJECTOR LATENCY: 20
I stoped accelerating when i saw the 10 counts of knock, i was like OMG!! So i stopped quick. These are the readings im getting from Evoscan. The evoscan settings are
Baudrate: 15625
timeout ms: 1000
openport 1.3x(FTDI/12PIN/SSM)
Mitsubishi MUTTIII
select ECU: EFI
injector scaling: preset at 512----i have the stock 240cc injectors rite now..whats the scaling for the stockers? 204@15% or 192@20%?
Do i need to change any of the Evoscan setings, or are those correct? If so, my next step is to eliminate knock by pulling timing right? i do this by logging a couple more times to make sure im getting consistant knock counts at this RPM (2,500) and i go into ECUflash, open the timing map and adjust timing at 2,500?
Or, do i do more pulls all the way to redline and record the whole powerband so i can adjust timing at multiple RPMs (2,500 up to redline) Whats the proper procedure for pulling timing? One degree or two degrees at a time?
TPS: 42%
COOLANT TEMP: 210
TIMING ADVANCE: 7
IPW: 13.312
IDC: 28.7
LTFT LOW:6.0
LTFT MID: 7.6
ARF: 12.4
AIRFLOW HERTZ: 431
02 SENSOR: 0.4V
MPH: 32
AIR VOLUME: 184
KNOCK SUM: 10 :-(
KNOCK VOLTAGE: 0.7V
OCTANE LEVEL: 100%
ECU LOAD: 88.125
Baudrate: 15625
timeout ms: 1000
Mitsubishi MUTTIII
select ECU: EFI
TPS: 42%
COOLANT TEMP: 210
TIMING ADVANCE: 7
IPW: 13.312
IDC: 28.7
LTFT LOW:6.0
LTFT MID: 7.6
ARF: 12.4
AIRFLOW HERTZ: 431
02 SENSOR: 0.4V
MPH: 32
AIR VOLUME: 184
KNOCK SUM: 10 :-(
KNOCK VOLTAGE: 0.7V
OCTANE LEVEL: 100%
ECU LOAD: 88.125
Baudrate: 15625
timeout ms: 1000
Mitsubishi MUTTIII
select ECU: EFI
TPS: 42%
COOLANT TEMP: 210
TIMING ADVANCE: 7
IPW: 13.312
IDC: 28.7
LTFT LOW:6.0
LTFT MID: 7.6
ARF: 12.4
AIRFLOW HERTZ: 431
02 SENSOR: 0.4V
MPH: 32
AIR VOLUME: 184
KNOCK SUM: 10 :-(
KNOCK VOLTAGE: 0.7V
OCTANE LEVEL: 100%
ECU LOAD: 88.125
Baudrate: 15625
timeout ms: 1000
Mitsubishi MUTTIII
select ECU: EFI
You should pull timing to get rid of knock, but also make sure your AFR is right and not too lean or rich, as that can also cause some knock.
Don't do pulls at WOT or Redline if you're seeing 10 counts of knock consistently. Try instead, pulling 1 degree of timing for each psi of boost. This isn't exact, and not trivial to do, because looking at the map you can't really just magically say "right here is 3 psi" but just as a general starting point, guess. Oh, and 1 degree of timing for every 3 counts of knock.
Don't be afraid to post your logs and let everyone inspect them, ppl love that stuff.
You should check in ecuflash, and use whatever the injector scaling is set to there, just put that in evoscan as well.
Make- mitsubishi
model- lancer
submake- oz rally
market- USDM
trans- auto
year- 2002
ecu id- "blank"
case id- MR578519
internal id- 88540021
flash method- mitsukernel
memory model- sh7052
checksum module- "blank"
inherits- 98720010
Any ideas? is this the part were i use the definition files? How do i put the definition files into ecuflash?
How do i post my logs from evo scan? also..ecuflash wont let me edit or view the rom data, the only thing i can view is the "init code" and "immobilizer" Not sure why i cant see anything else, i selected "developer level" as well still no luck? Here are the ROM INFO:
Make- mitsubishi
model- lancer
submake- oz rally
market- USDM
trans- auto
year- 2002
ecu id- "blank"
case id- MR578519
inherits- 98720010
Make- mitsubishi
model- lancer
submake- oz rally
market- USDM
trans- auto
year- 2002
ecu id- "blank"
case id- MR578519
inherits- 98720010
read this: https://www.evolutionm.net/forums/ec...-tune-evo.html
this is the videos: https://www.evolutionm.net/forums/ec...-ecuflash.html
and here is master list: https://www.evolutionm.net/forums/la...ster-list.html
Well, you need to have the proper info files to view the actual data, but if you can see 2 things, then that's sorta weird. Find Senate's post called like, "master lancer definition list" or whatever and download that. Put the files in the ecuflash folder, and make sure in the ecuflash menu that the options point to the folders you just unzipped to, for like rom meta data and definitions or whatever they are called. Also, I think you need to watch the ecuflash videos. let me find the link for them.
Well, you don't need them all, but it doesn't hurt to just have them there. They are used when you open the ROM for your car, and the definitions interpret what is in the ROM. You put them in a folder, any folder really, and then in the options menu of ecuflash, you point ecuflash to using that folder, then restart ecuflash.
