Community Tephra Tweaking
#961
Yes but you would need something for the map sensor to work off of remember its speed density not alpha N which is more of a ITB setup.
What SD needs is a vacuum line behind the ITB plate probably all 4 of them tied into one line for a good average.
If the car was to be tuned Alpha-N style the whole system would need to be reworked.
#962
Its a race car system basically its all guessing for the motor it equates load directly tied to throttle percentage and delivers fuel based on that. So since it requires only a throttle input its super responsive and fast but not accurate.
It can't be used on a boosted system without a correction for pressure.
#963
#966
the items in the "current rommetdata" column...basically like a brief explanation of each bullet in "x" category. i did look through the stickies and didnt find anything...another member asked the same question, but was never answered. i quoted and posted the same question in the thread as well. i know the basics, but just wanted to have an insight on what all the other stuff does
#967
Look for merlins guide to tuning evos Google it if you have to. There is not a better more complete explanation for everything in tuning in existence i can assure you.
#968
I'll take "looked through" as really skimmed through the stickies for names exactly matching your problem?
#969
#970
what does the P0830 Clutch Pedal Circuit do? and if it is set to 0 it should be disabled right now correct or by default? if i set it to 1 should that let me start the car without pressing in the clutch or with a remote start???
DormantBeast
13
Jul 9, 2017 07:38 AM
Evo_Goodness
Aug 30, 2016 04:00 AM
