do our cars have an idle relearn procedure?
Old Oct 10, 2011 | 12:00 AM
jwick76's Avatar
I was just reading up on a P0507 code, and found this in a nissan forum. I was wondering if Mitsubishi has anything like this going on with the lancers or their fleet at all?
http://www.nissanforums.com/l31-2002...0507-code.html
I found it interesting that the ecu can learn this way on a nissan, didn't know if it was somewhat universal with jdm.
Old Oct 10, 2011 | 10:42 AM
burner67's Avatar
very interesting i wouldnt be surprised if we did.
Old Oct 10, 2011 | 10:45 AM
ryancb's Avatar
As far as i know thats the pull the battery for 30seconds then reattach and start the car and let it idle for 10-20mins.
Old Oct 10, 2011 | 12:26 PM
RoadSpike's Avatar
Our cars have a idle auto adjustment feature in the rom.
Basically what the car does is start with the ISCV settings in the rom. It will then compare the idle speed to the desired idle speed set in the rom. If the setting is off it will wait a set number of ms before adjusting the idle stepper by 1. It will continue to adjust the idle stepper until it reaches a maximum of 4 which is the default in the table. It increments or decrements the idle stepping based on the idle being higher or lower than desired.
Tables involved:
Idle ISCV vs coolant temp (both ac on and off)
Desired Idle (ac on and off)
Idle settings table (don't know if its defined for you guys)
While I haven't personally seen a car get an error code on the ISCV its probable that the error occurs because desired idle is higher or lower than the ISCV combined with the range of adjustment can provide.
Solution would be to adjust the BISS screw to compensate for your settings such that the car would be back in range for controlling the idle.
ATM Blazin
Lancer Troubleshooting
35
Aug 15, 2015 08:47 PM
sam0329
Nov 24, 2013 11:50 PM
OZboyee
11
May 22, 2013 10:56 PM
ragyan03
May 10, 2013 05:18 PM
Quick Reply: do our cars have an idle relearn procedure?
