how to tune for fuel saving during idle?
Not really sure why you would be worried about fuel saving at idle. Even if you got your tune absolutely perfect at idle for saving fuel you would maybe save a gallon a year or less. Cars use very little fuel at idle.
It runs o2 sensor closed loop control at idle so regardless what you put in the fuel map it still looks for 14.7 , if you disable o2 sensor control and force it into open loop then it runs from the fuel map , but hardly worth the hassle
jcsbanks
Oct 7, 2006 02:25 AM
Jeff_Jeske
Apr 19, 2006 09:35 AM
