Cry02?
Cry02?
I ran past this stuff a few months ago when it first debuted and completely forgot about it until today when i saw it in a Sport Compact Car magazine. It had won some kind of award. Anyway, would this stuff work on a lancer? Would you see any gains from it? Its like 300.00 and says it cools your air by 60%, which I think would yield some gains, but I wanted to see if anyone has had any from of experience with it.
The CryO2 Air Intake consists of an aerodynamically designed bulb with a cryogenic chamber which is mounted in a 4" segment of air tube. The air passes over the bulb, heat is removed from the air charge resulting in a colder, denser, more powerful charge. Dyno testing showed a reduction in intake air temperature of more than 50 degrees. The CryO2 Air Intake can be used on turbocharged, supercharged or naturally aspirated applications. Multiple units can be used for colder results. Installs in minutes and comes with silicone connection sleeve, hose clamps and connection / vent hose.
Originally Posted by OZ-Guy
me either.. i'm trying to find out though. i know it doesn't mean anything usually, but it won some kind of award.. gotta be worth something..
