Oxygen Sensor
Oxygen Sensor
I am attempting to install my header and downpipe. Can anyone tell me how to remove the oxygen sensor from the exhaust manifold.. If i can get this off I will do the install. Seems like a piece of cake to do.
Thanks
Thanks
disconnect it (plastic clip), get a o2 socket wrench (just buy one they are cheap), sit it to the side, take off your exhaust manifold, now work backwards... if you have the rrm header, it is easier if you put it on off the car then reconnect it after you have the header installed
-eric
-eric
If your manifold is anything like my megan in my evo. You will need a crows foot oxygen sensor socket. I have a deep socket one with the slit and it does not have enough clearance for my exhaust manifold.
Carlos
