how to tune apexi safc2
Old May 28, 2005, 12:55 PM
Ozdriver's Avatar
how to install and tune apexi safc2
I'm looking into getting the safc2 but I want to know how to install it and how to tune it if anyone can help I would appreciate it thank you.... I have searched this topic but the only how to I have found was for the s-afc and I wasnt sure if there was a difference with the install
thanks
Old May 28, 2005, 01:27 PM
Blacksheepdj's Avatar
Install is the same. You just wire it into the ECU.
Tuning - it's very easy, and it'll come with instructions. But if you are DIYing the tuning, get an EGT guage and maybe an A/F guage - if you go too lean, you blow the motor.
PS - there's an install listed in the How To forum for Lancers.
Old May 28, 2005, 01:56 PM
Ozdriver's Avatar
I read the how to on the install but I had more wires than he mentioned in the instructions
Old May 28, 2005, 02:22 PM
yellance's Avatar
also ask rhyzin he has it installed on his lancer
Old May 28, 2005, 03:48 PM
oz4g94's Avatar
does anyone know if the apexi safc 2 will give the same results as that of the rrm piggyback.
Old May 28, 2005, 09:45 PM
KillahB's Avatar
I dont know what variables are adjusted in the RRM piggyback, but keep in mind, it is a fixed piggyback and not variable like the AFC. Conversely, the AFC can only adjust air / fuel ratios based on your mods, and there is no timing control.
Old May 28, 2005, 10:12 PM
rhyzin's Avatar
it'll give similar results. the rrm piggy has more cells of adjustment so it's a bit more responsive and flexible. but as AQ said, the rrm unit is not adjustable unless you can get the laptop software, which is extra.
Old May 29, 2005, 07:53 AM
Ozdriver's Avatar
does anyone have a wireing diagram or anything that would tell me how to install?
Old May 29, 2005, 08:23 AM
Ozdriver's Avatar
I just went through the how to again and a i still have 3 extra wires purple yellow and blue are these not needed for installing for our car?
Old May 29, 2005, 10:12 AM
I think all the wires on mine went to something. But I had a buddy do it.
Old May 29, 2005, 01:13 PM
rhyzin's Avatar
nope. some wires don't get used. they're for other cars that have more than one airflow sensor. the safc II type 2 also has a knock sensor.
here's the install with pictures.
https://www.evolutionm.net/forums/sh...=s-afc+install
you think a mod can update the thread in the "how to" to the orginal post? i had to update it cuz the original host of the pictures went down.
Old May 29, 2005, 01:56 PM
Ozdriver's Avatar
thank you I had already installed the afc but the pics and all made it a little more reassuring.. thanks again for all the help guys...
I didn't hook up the o2 sensor because from the sounds of it in the how to it could mess up my car any one have any input on that?
Old May 29, 2005, 08:29 PM
KillahB's Avatar
I have the O2 sensor mod wire hooked up on my Mirage and have had it hooked up for about two years now, with no ill effects.
Old May 30, 2005, 08:25 AM
airlinevomitbag's Avatar
Have fun tuning it. There is a lot to lean out. I have been messing with mine again lately because I was sick of 25mpg and hitting rich on my A/F at 25% throttle. I got her up to about 33mpg and it only cycles in the stoic range while I am regular driving instead of hitting a bar rich and a couple bars lean. Getting the rich out definitely wakes the engine up. I set my Lo/Hi throttle points at 15 and 65 and it seems to do well for me. Can't help with what to take away and how much. My MAS screw is backed out I use a 190lph fuel pump and a different regulator, kamikazee header/dp, testpipe and greddy, so mine is a little goofy.
Old May 30, 2005, 12:53 PM
blaze_125's Avatar
What are the main differences between SAFC and SAFC2?
Quick Reply: how to tune apexi safc2
