Camshaft Position Sensor Install?
There's been some general discussion about replacing a bad camshaft position sensor. Can anyone provide a detailed set of instructions? What tools are needed, what (if anything) needs to be removed to get to the sensor, any possible problems related to replacing it?
Thanks in Advance.
Tom
Thanks in Advance.
Tom
I believe the process is the same with the Lancer. You will need a wrench with a 10mm socket and that is it. Really straightforward process. I changed mine in about 5 minutes, if that.
Thanks in Advance.
Tom
Thanks in Advance.
Tom
I understand that it's a pretty easy deal. Would it be possible to post a photo of exactly where it's located? Does anything (air filter housing etc...) have to be removed to get to it?
Oh. Please be concerned with my mental well-being anyway
Thanks.
Thanks.
I just had the same problem (posted on previous thread) and ordered the part.
AllData.com (DIY section, subsciption for repair manual) recommends taking the air filter. Doesn't look liek a bad idea - theres only about fifteen degrees to move the ratchet. I wasn't able to loosen the bolt much - may have been my old rachet.
I was able to retighten it; interestingly, the service engine light (code P340) hasn't come back on since. I was having some severe vibration from my tires; maybe this could have loosened it?
In any event, how many people have had this code come up, and how many have had to replace the sensor?
As I have searched the site and the internet for more helpful information, I am yet to find an actual picture of the device installed on the car in question. I am still confused on where it is.
RSGuy
13
Mar 3, 2020 12:04 PM
DSMMR21
May 17, 2013 11:31 AM
Blitz
Dec 24, 2011 04:55 PM
RALLICAT
Oct 8, 2006 04:06 PM
