Engine Problem
Engine Problem
I took out my stock airbox to put in a SRI. I noticed that my vacume line was sucking oil out of my engine and putting it in the intake. I asume this may be valve seals but im not sure. How much dammage might this caused? Any suggestions or Input is apreciated. My car is running like a 2 stroke and I dont like it.
Let me list all the problems and what I have checked
PCV valve = good
intake and vac line = has oil in it
spark plugs are white on the tips and burnt on the ceramic = leaning out
I was going to do a compression test but it doesnt look like my tester is long enough to fit down to the cylinders.
PCV valve = good
the oil in the lines is normal. it's supposed to take excess pressure from the head as well as the pcv valve.
the plugs might be more of a clue as to what it could be. any pics?
Brettpeters
35
Feb 21, 2014 10:24 PM
LancerEvoV
95
Sep 24, 2002 08:06 PM
