header question
header question
ok gettin headers soon but not exhaust.. i am going to slowly build my car to drop a turbo in but heres the deal.. should i go ahead and get a catback 2.25 with the headers or just the headers with stock piping.. will the stock piping be able to handle the headers.. will a decent axle back help? because if i drop a turbo in im gona have to end up getting a biger exhaust anyway so yeup... any thing will help thanks!
-rhein
-rhein
switching headers will not in any way affect your exhaust. All your doing is switching from a cast iron header to an aluminum(I think...) header. If you get one that is ceramic coated, that is even better because it keeps the heat at bay.... in other words it keeps the engine bay cooler which makes for a happier motor.
But I wouldn't buy the header first. To be honest with you I wouldn't buy any of the exhaust until you buy the turbo. I've been thinking of putting exhaust on mine but when it gets down to it your really not going to see TOO much of an increase in power. It just sounds better. Just play the sleeper approach and leave the exhaust stock until you get a turbo... that way your friends will be like ...what in the world did he do?!
If I was in your situation I would get the RRM Header with a custom downpipe. I wouldn't buy a catback exhaust until it was time for turbo. If the turbo is still quite a ways away then an axle back would be fine (I would get it).
an exhuast does make a little bit of a difference. first thing i did was a magnaflow catback.the car sounded better and responded better. especially when rev matching and heel toe. yeah its really only good for say 3-6 hp. but couple it with a cai for another 3-6 hp and it will be even more responsive. and you might actually [feel] a difference. other wise, hold out on the header until you go turbo.
Yes, you can put the header on the stock exhaust.
But I still say it's stupid if you're going turbo. You're buying a part that you KNOW you'll be removing later...
