Intake Issues!
Originally Posted by Skylineracer
drive around for 15 min between 50-60mph i think it is to run the drive cycle on your car.
https://www.evolutionm.net/forums/sh...8&page=2&pp=15
try to hit on ramps, off ramps, different speeds, accelerating, decelerating, idle, downshifting (if manual), etc. all of this is intended to let the ECU relearn the fuel map.
Originally Posted by blaze_125
something else just came to my mind. Way back when I installed my SRI, nobody in Canada carried the MAF adapter plate so I had to make my own. If you had to remove the plastic plate that's on the front of the mas, the adapter plate has to properly cover the maf opening. If it doesn't cover it like the stock plastic peice, the ECU WILL throw a code and the car will run like crap since there is way more air coming in, than the ecu accounts for.
I agree completely. That plastic piece that covers the opening of the tube on the inside of your stock box is what is causing your problem. I was having the same problem so to try to figure it out I just put the stock box (the part that connects to the maf, but left the other half off) and started my car and it ran fine. Then I pulled the box off and it ran like sh**. So I put it back on piece by piece and found out that the little black piece with the lip on it was causing the problem. STUPID!! Does anyone know about an easy fix for that?
Ok folks update:
Problem solved. After a little bit of thought and initiative, I frankensteined some peices from the aftermarket intake to the stock intake and got it to work just fine. Runs and sounds good. Thanks for all the help
Originally Posted by JesseFriz
Ok folks update:
comatose721
Lancer Troubleshooting
15
Jan 11, 2008 10:28 AM
vtluu
Apr 12, 2004 09:54 PM
