cedia and US Lancer
Well...let's see here...hmm...
Alright, the Cedia is an AWD baby Evo. It puts out 130 at the flywheel which ain't to bad. Also, they come only as an automatic (running the very nice MIVEC-II tranny though). The only real parts that would be capable of fitting probably are cosmetic pieces and perhaps some suspension stuff (probably front only). As for engine components, you might want to do some research since they engines may still be the same.
OK, Cedia IS Lancer, the whole name of JDM Lancer is called Lancer Cedia (Centry Diamond)...
Not ALL Cedia are AWD. This car is avaiable in 2WD/AWD, both MT/AT (Although MT is very very rare). On the other hand, ALL Cedia are equipped with 1.8 GDI engine (Gasoline Direct Injection) which is very different from US spec 2.0 4G94 engine.
The parts you'll find from a JDM Lancer Cedia would most likely be suspensions, exterior/interior parts.
