The 4G63 into a Lancer mega merge thread
#61
The only thing that I know of that would be illegal is tryign to pass the car off to the authorities or insurance as something it isn't. IF you want to carve your car up and spend 15K+ on it that's fine, as long as it is still presented, for instance, as a 1999 Mitsubishi Mirage DE, then that's fine. If its wrecked or stolen, just be prepared to nly get what that book value is for that particular car.
For engine swaps you are just (supposed) to use an enigne no older then the chassis and leave all the emissions contorls in place. I'm suuuure he's going to do that.
#62
In the great state of PA
what your car is registered as is what it is regardless of what it looks like. Now the only problem is the emmisions and inspection. You are required to pass inspection as the car that is registered. In other words, if you have a car registered as a Mirage but its awd, you fail.
Illegal: Buy wrecked Mirage and import an Evo V. Swap VIN from Mirage onto Evo and register as rebuilt.
Legal: Buy wrecked Mirage and font cut of Evo V plus rear suspension, axles, drivetrain. Rebuild Mirage into USDM Evo V. Register as rebuilt. YAY.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
#63
I'm fairly certain both things are illegal. Remember when it comes to cars the law is pretty damn strict and there are all kinds of rules and regulations that need to be followed. I would strongly suggest talking to your insurance provider first to make sure they'll cover you if you attempt this.
#64
but the cars are similar enough that you could actually swap almost the entire front end to the lancer. the fenders, hood, headlights, and front bumper would all fit as long as you use the VII, VIII, or IX radiator support. a lot of the suspension mounting points are the same as well. i know the control arms and crossmember as well as engine and trans mounts are different, but not sure about the steering rack or anything else.
#68
Ive done the reaserch for Pennsylvania. What i said was legal here. In PA as long as the chassis went through DOT requirements to be legal in the states whatever parts you put on that chassis is your choice. It just has to pass inspection and emmissions. That is why you see alot of 10 sec and lower street cars here. Its also why our insurance rates are so high(i think).
#70
In Delaware, I could put anything under the hood I wanted as long as the exhaust gases were within standards. In Missouri, as long as the safety equipment worked (i.e. lights, horn, etc. - I don't think they checked the brakes though) it passed. In South Carolina, it's on the individual to ensure their vehicle is "safe"...there are no inspections. In California, my vehicle failed because it didn't have the heat riser from the exhaust manifold to the air cleaner ('72 Monte Carlo, back in 1994...figures it'd be exempt now). It just depends on where you are. As for the insurance issue, again, it depends. I've talked to some insurance companies and they would only pay book value. Others would cover any modifications as long as they knew about them (if they exceeded a certain price range you had to buy extra insurance though). The best thing for someone to do is check with their DMV, insurance, and maybe even highway patrol to see what restrictions apply to them. To discuss what is legal in your area and try and cast it out on the rest of the world is pointless.
Back to the original idea of an engine swap though, for the 4G64, you would not want to use one from a 1g or 2g Eclipse due to the opposite orientation. I'm not 100% sure if an Evo VIII or IX 4G63 would work, but I know many people are putting those DOHC heads on our engines (I have a 4G64 in my 03 Eclipse). People are also taking the 4G64 bottome ends (or just the cranks and aftermarket rods, pistons, etc.) in Evos. Both seem pretty easy. Another alternative for the 4G64 is that some people use the Kia Optima head. It's a DOHC head similar to the Evo, but with a larger combustion chamber (lower compression)...this'd be great for a turbo setup, plus you could use Evo cams, etc. Basically, find out what's legal in your area, ask your insurance company if they'll cover it, and then start planning your swap accordingly. Your initial idea of posting a thread to ask what would work was a great start, it just got shifted off course by people who don't like the idea of a swap. In my opinion (and since everyone else gave theirs, I figure I'll give mine), I don't like any vehicle as it leaves the factory. What works for mass production and a company's focus towards efficiency, polution, performance, and profit usually does not work for my ideas in what I want in a car. I usually view cars simply as a platform from which I can build a vehicle that suits my desires.
#75
There is no 4G63 that will fit in a Lancer to my knowledge. Obviously, anything is possible with enough time and money and effort. There's a 4G64 swap posted in this forum (look at the threads near the top), but no real hard info on the 4G63.
