lancer/caliber same k and n intake??
Old May 27, 2007, 03:18 PM
Registered User
nawtyboy03's Avatar
i was looking at the k and n intake installation guide for the caliber and i believe it is the same type engine, i am not to sure on the mass airflow sensor. anyone else know about this?
Old May 27, 2007, 07:30 PM
Registered User
nawtyboy03's Avatar
MOPAR parts?
they have a mess load of parts for the caliber, same block right? well they have headers for it as well as CAI........would it work??
Old May 27, 2007, 08:23 PM
Mystic_Korean's Avatar
Same BLOCK, not the same head. The intake goes to the head. The header comes out of the block.
Old May 27, 2007, 11:23 PM
David Kelly's Avatar
I don't think so. The Caliber Air filter sits further away from thr block than the lancer's does. The tubing on the Lancer also has a much steeper vertical slope than I see possible for the Lancer.
I do have the Caliber one installed on my cali, though.i may try it.
If it does work, I would suggest even buying the Part for your lancers. It improved the way my caliber sounded and picked up immensely.
Old May 28, 2007, 09:05 AM
EvoM Administrator
otter's Avatar
Go to the autoparts store and take your air filter inside with you. Compare it with K&N's until you find the right one. It might even be the same one that previous lancers use. Also, K&N's site already shows an oil filter for an 08 Lancer, so I'm sure they'll have an air filter listing up soon, too.
Old May 28, 2007, 09:19 AM
N1te's Avatar
Which engine on the Caliber's is similar?
Old May 28, 2007, 09:54 AM
EvoM Administrator
otter's Avatar
Both. Caliber uses the world engine. Basically, three manufacturers threw all their engineers into a room to design a basic engine layout, then after that each manufacturer makes their own tweaks, and finally they all share the same production facilities.
http://en.wikipedia.org/wiki/World_Engine
Old May 28, 2007, 03:17 PM
That is a negative. The Caliber's intake on the throttle body is way down on the bottom of the engine, deep beneath the coolamt hoses. the lancer's is right up top, with the intake pipe about a foot and a half long. the calibers is about 2.5 feet long.
like i have said before, though. i guarantee there is an intake that will fit on the market somewhere right now. this guy has the right idea with the comparison.
Old May 28, 2007, 03:59 PM
08gts's Avatar
Exhaust manifold or header comes out of the head also. The Head has both intake and exhaust valves. On The 08's transverse engine the intake manifold is on the front and the exhaust manifold is on the rear of the head. There is no guarantee that the mopar header would work. The K & N intake for the caliber is close, but I don't think it would work without modification. You would be better off using an intake and header that is designed for the car.
Old May 31, 2007, 12:23 AM
My bad. But the point is that the Lancer and the Caliber DO NOT share the same head... the share the same block only.
Old May 31, 2007, 06:21 AM
Blacksheepdj's Avatar
We just need someone to do this. K&N lets you search by filter size. If I get time one day, I'll try and pull mine, but I don't plan on that happening anytime soon...
http://knfilters.com/search/univ2.aspx?ID=S0005
Old Jun 2, 2007, 09:36 AM
Registered User
nawtyboy03's Avatar
link to page
http://www.knfilters.com/search/prod...x?Prod=63-1552
this is a link to the k and n caliber page, it shows installation instructions and to me the engine looks the same. the only difference is the mass air flow sensor..
Old Jun 2, 2007, 09:47 AM
Registered User
nawtyboy03's Avatar
http://mopar.com/performance/street/caliber/index.html
here is another link to the mopar site, tell me what you guys think, compatible? or not?
Old Jun 2, 2007, 07:32 PM
specialk8519's Avatar
They do look alot alike. We just a need a ginnie pig to try them out.
Old Jun 2, 2007, 07:38 PM
About every single Mitsubishi for the last 10 years has used the same K&N air filter. Could work for the 08 too.
LOOK http://www.knfilters.com/search/appl...x?Prod=33-2105
Im going to try and go to Auto Zone and Advanced Auto Parts on Monday or Tuesday and give it a shot and see what happens.
Quick Reply: lancer/caliber same k and n intake??
