Engine Sounds Like A tractor
So it started happening recently and I have no clue what, or why it is doing this. But my engine sounds like a tractor, and when its in the 1000-2000rpm range, you can hear a metal clanking of sorts. when its over 2000rpm it sounds fine, but i attached a clip of how it sounds. You can not really hear the clanking, but i cant really track it down either. All i know is that it is coming from the passenger side, by the timing belt, area.
Engine Sound Clip
Any ideas... cause i sure as hell am stumped.
I am gonna do the timing belt soon, and its about 10,000 miles on the plugs, but i want to see if i can fix it, before i turn it over to the dealership mechanic
Engine Sound Clip
the PCV valve has never been replaced, and I am just worrying myself cause it ran quiter before. that noise isnt as bad as the one that shows up in the 1000-2000rpm range
i am definitley looking at new plugs either this week, or in august (im going away for 2 months so the car is just gonna sit).
did that saturday a week ago.... actually now that you mention it... i had it done at the midas i always go to , and it didnt make noise before then....
im gonna go check out the oil situation
ok so the oil is a little low, im guessing it never got checked after they filled it, and i didnt either
im gonna add a little, change the plugs, and pcv valve, and hopefully itll be better.... thanks everyone
