CAI whistle after exhaust install???
cypho you are right. At times it could be an exhaust leak from bad gaskets. If you didn't replace your exhaust mani gasket you could be loosing power and have exhaust leak...and that goes same for exhaust systems.
my friend had a problem with his car similar to this, he had a whistling noise coming from his car when he installed a catback exhaust and headers, he found out it was due to air leaking through the flex pipe at the end of his downpipe because he still has a stock downpipe and once he changed that out it was gone,
dont know it could be similar cause it definitely sounds like an exhaust leak if you ask me, just my opinion
