civic injen intake on a Lancer?
Old May 1, 2002 | 06:43 AM
lazerlancer's Avatar
I have a Injen intake for 01 civic does anyone if it will fit my car?
Old May 1, 2002 | 06:54 AM
Wallesasuaz's Avatar
Exclamation depends...
IT depends... what type of inake is it?
if it's a regular racing intake from injen, it might have a chance.
but if it's a COLD air intake, they are made specifically for a car.
go www.injen.com
Old May 1, 2002 | 07:20 AM
its a regular racing intake
Old May 2, 2002 | 12:39 AM
okay, racing, that means it's short... umm.. is it left or right side mounting?
Old May 2, 2002 | 02:39 AM
right mounting
Old May 2, 2002 | 08:53 PM
Alien_Lancer's Avatar
i need help
aight i ordered the weapon r intake off of ebay but never got all of it but now am getting my money back all i recieved was the piping and the sleeves i want to just use that piping and put a filter on their but i have an air flow mass controller and i dont know what to do about it what should i do
Old May 2, 2002 | 09:20 PM
Autobot's Avatar
Re: i need help
The piping is used to replace the stock rubber tube going from the throttle body to the air flow meter (AFM). Use the 3"-3" reducer sleeves and zipper rings to secure everything. You attach a 4.5" adapter to the other end of the AFM and attach either a 4.5" filter or you can use the 4" Weapon R Dragon if you clamp it down with zipper rings and a 4.5"-4" reducer sleeve.
As for the Injen for the Civic...I think that the inlet size of the filter would probably be about 3" and Mitsubishi vehicles require a 4"-4.5" so I don't think it would work.
Hope this helps.
Old May 2, 2002 | 09:35 PM
i want to use all of the piping so i need to take out the air box and factory intake is that what your talking about
Old May 2, 2002 | 09:38 PM
Autobot's Avatar
Yup. You take everything out from the plastic ram at grill all the way to the rubber tube at the throttle body EXCEPT for the air flow meter with the wire attached.
Old May 3, 2002 | 12:34 AM
unhdsm's Avatar
I'd be impressed if it fit on a mitsubishi MAS.
Old May 3, 2002 | 12:40 AM
Autobot's Avatar
Well no, of course it won't without an adapter.
Old May 5, 2002 | 08:56 PM
all right i get everything of what to do but how am i going to attach the AFM to the new piping
sofly1990
12
Mar 9, 2010 11:12 AM
jpendon
Feb 15, 2006 11:05 PM
ModifiedOZ
Aug 31, 2005 08:02 PM
Chow
Jun 23, 2003 04:27 PM
lanceroz84
Lancer Engine Tech
15
Feb 27, 2002 09:26 PM
Quick Reply: civic injen intake on a Lancer?
