When should I change out my CAI filter?
Old Nov 3, 2009 | 10:24 PM
  #31
BABYGOTBACK's Avatar
^ Just purchase the recharge kit and it has instructions with pictures. You can probably also google search how to clean a air filter using the K&N recharge kit. It takes more time to allow the filter to actually dry, then the whole process! Good luck
Old Nov 4, 2009 | 07:29 PM
  #32
yahu's Avatar
^what he said. Doesn't sound like you've done it before OP. Just follow the instructions and you'll be set. I think BGB or someone else said it earlier too - don't completely soak the filter with oil when it comes to that part as you don't want any getting past the filter into the MAF or turbo.
Old Nov 4, 2009 | 09:47 PM
  #33
Just make sure you don't use a air compressor hose and blow stuff out of the filter. You can damage the filter, and break apart the mesh screen. Just a soft toothbrush and the cleaning solvent in the kit works great. Rinse it out with water, not too high of pressure water. Let air dry over night, and then lightly spray the filter with the provided oil. You want to spray just enough to get the red color of the filter to darken slightly. Good luck, it is a easy and cheap fix!
Virus1x
Aug 21, 2015 12:23 PM
E\/0 X
Aug 15, 2012 06:10 PM
AntiBlitz
14
Oct 6, 2010 10:31 AM
kraig
Lancer Engine Management / Tuning Forums
11
Apr 22, 2009 05:14 PM
Digiflame
Lancer Troubleshooting
Dec 15, 2007 02:42 AM
