Need some opinion on engine swapping for my 03 Lancer ES
Making my Lancer my project car for the summer for 2011....saving up some money to put work into it want to make it real fast... would get an evo but idk i like the Econ body better for some reason.... want to know what i can drop in...as of now its a ****ty automatic tranny.... want to swap engines and turbo the **** out of it. My cousin told me i should get a eagle engine for it but I want to make that **** move... any suggestions? dream goal is to reach 300-400hp if possible..... Miracle goal is to make it 10sec car
i made 275 at 15psi on a stock block and that was hard even with a turbo.
there are a few guys close to making 300hp but its hard and costly and not to mention a lot of work in building and tuning...
he can get 300 with the 4G64 swap only if he puts a turbo on it easily at 18-20 psi and im pretty sure he can do that with stock internals.
check out JRR's for sale thread get your feet wet with a turbo first before installing a brand new motor in that way you know what to expect
edit*** you can also put an evo 8 head on the 4G64 block and basically have an evo motor
How many successful engine swaps have we seen, 4? I think if your idea is that it will just magically drop in like a honda swap, you need to search through the fourm and read the other swap threads. It's pretty well documented by darkmitsu, all your answers will be in his thread.
theres a 3g guy that did the g64 block with evo head and ran 15psi stock internals, and he ran low 13s on street tires with no traction, imagine the same in the lancer which is several hundred pounds lighter.
even guys that keep the 4g64 sohc and then boost it end up with about 250-280 at the wheels at about 10psi. the 4g64 handles boost very well. but traction will become an issue.
A local guy once did a 4G63 head from a Hyundai Sonata with Blox 272's onto the 4G64 in his Galant. This was a while back though and not even sure what ever happened to the guy.
thanks for the insight, gonna start saving up and keep you guys updated with my soon to come mods for this upcoming summer(long way to come I know lol but mods ain't cheap). If you guys have anymore ideas on what i could swap in that would be awesome.
j-motive
May 10, 2010 09:27 PM
ziggy
Nov 11, 2003 07:32 PM
