2009 GTS Proper Maintenance
Hello All,
My wife currently drives the 2009 GTS. I've neglected the car in terms of proper maintenance since I've babied my own car(2004 Honda S2000). We've always changed the oil every 3K miles but now am going to change the oil myself and use Synthetic. I also recently purchased a cabin air filter to switch out. I've changed the air filter recently.
What other proper maintenance measures can I do myself to ensure this car runs smoothly for a while or until I decide to trade it in once we have kids.
The car currently has 30,000 miles and is an automatic transmission.
Thanks in advance.
Thanks in advance.
Trans fluid flush change would probably be a good idea, but make sure you get CVT fluid. Check out the drivetain forum:
Check out post #2 and #26
https://www.evolutionm.net/forums/la...ion-flush.html
Nothing much more then what you are already doing. Just ensuring that you are getting the oil changed on a regular basis, which it already sounds as if you are. Then getting your transmission fluid changed, keeping an eye on the brake fluid too
. If the car came equipped with the allergen filter, making sure that as wel as the air filter don't need replacement either. The car will tell you if it needs any immediate attention anyways .. goodluck!
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
at your milage do the tranny fluid change... at 60k another tranny fluid but if your **** about upkeep then do full power steering, brake fluid etc... i usually do the air filters every 15k and mobil1 synth every 4-5k
Regular maintenance on these cars is reasonably easy. Do a search of my username, and you'll find a couple of how-to articles on the subject, including a detailed 30K service.
Here's the one on 7,500 mile service:
https://www.evolutionm.net/forums/la...ance-25-a.html
Here's the 30K service:
https://www.evolutionm.net/forums/la...e-service.html
go_dlee
Evo X How Tos / Installations
Aug 24, 2010 11:07 PM
Mark Hubley
Lancer How Tos / Installations
Dec 29, 2007 08:16 AM
Mark Hubley
Dec 29, 2007 08:14 AM
