Kamikaze Header
Old Feb 20, 2004, 08:31 AM
  #121
sdhotwn's Avatar
well the spinning of the tires in and of itself is enough to create the difference.. heavier rims will also make a decent difference... and extra weight could also add some difference. So there are enough factors that I'd guess added up to the difference. Best way to be really sure is to run each car like 5 times and time them specifically over a certain distance. or run them several times varying your approaches and seeing what differences you get. Also where you shift or so forth will make a diff. Shift just shy of 6K on each shift. You should also do the cars from a roll.. that will help the issues with traction. do a 10 mph roll and go once you hit a certain point.
Old Feb 20, 2004, 08:40 AM
  #122
Punk8981's Avatar
yeah thats what we should do, do a 10mph roll and then run. Thanks man, just thought my car had a little advantage coz of the Catback over his stock exhaust but 1/2 a car length tells me that it didnt. Surprised and worried i might have lost low end power coz of too much air free flow. Anyway he'll strap on a DC twin Canister Catback today, and its raining like **** today so maybe when it gets dry. Last night was damp, a lil over 30 degrees but when we got to the spot our tires were already wet. so might have cost some problems there also
Old Feb 20, 2004, 08:45 AM
  #123
Punk8981's Avatar
also we tried 5 times and my car just couldnt hang.
Old Feb 20, 2004, 08:48 AM
  #124
sdhotwn's Avatar
it is possible that you lost some low end, but i'd kind of doubt it. It's not real common to have that problem even though everyone thinks that it happens all the time etc... Be interesting to see what happens once he puts on his exhaust.
Good luck and be safe!
Later.
Steve
Old Feb 20, 2004, 08:50 AM
  #125
Punk8981's Avatar
well race again once he puts it on.
Old Feb 20, 2004, 10:15 AM
  #126
.L.
.L.'s Avatar
i smoked you sucka' . j/k now dont get us wrong guys..... we're not going out there street racing at every stop light. its actually an industrial back road that is absolutely DEAD at night, so no worries. anyways we're simply conducting an experiment with bolt on's.
Old Feb 20, 2004, 10:30 AM
  #127
TeamNeXusOz's Avatar
with an N/A setup ...if a car has an inatke and header...and coparing it to the saame car with intake header and catback... the car witout the catback will usually be faster...you should take your catback off and see if ster...it usually will... your car will run faster...i cant really explain why it just does has something to do with back pressue or soething like that....try it out and find out for ur self
Old Feb 20, 2004, 10:37 AM
  #128
.L.
.L.'s Avatar
yeah thats why punk8981 is eager to compare. he wants to see if the magnaflow is comparable to the dc twin cannister design. i'm not sure, but maybe the design will yeild different results. i guess we'll have to wait and see.
Old Feb 20, 2004, 11:45 AM
  #129
Punk8981's Avatar
in that case, why bother spending money and making the car only sounds louder? .L. smoked me? u would have if it wasnt a 1/2 a car length
Old Feb 20, 2004, 11:51 AM
  #130
.L.
.L.'s Avatar
calm down brotha'. we need to do some more reasearch on the subject. by the way, does anyone know what kind of gains are stated by magnaflow?
Old Feb 20, 2004, 12:19 PM
  #131
KoreanEvoVII's Avatar
where do i purchase a kamikaze header? i want one
Old Feb 20, 2004, 01:26 PM
  #132
IILANCERII02's Avatar
www.bigjoshracing.com
the header is nice but it makes it loud as hell.
Old Feb 20, 2004, 01:37 PM
  #133
.L.
.L.'s Avatar
yeah it should be around $260 shipped. also, as far as the sound goes...... it all depends on the setup. my buddy's got intake, kamikaze header, and magnaflow catback exhaust. his exahaust tone is medium (on a scale from low, medium, high, ear-bleed-high ). some people with custom pipping setups, universal mufflers have had a high/ear-bleed-high result. so it all depends on what you choose.
Old Feb 20, 2004, 02:23 PM
  #134
HobieKopek's Avatar
The biggest determining factors in sound are your muffler and catalytic converter followed in 3rd by piping diameter.
Old Feb 21, 2004, 08:09 AM
  #135
i think ill just go buy the magnaflow catback and then the headers
Quick Reply: Kamikaze Header
