fuse and electrical questions
Alright so I swapped a new(used) 4g94 into the lancer and I have everything hooked up, but there was a loose ground when I connected the battery cables and sparks flew everywhere. Blew the three fuses in that second fuse compartment right next to the main one in the engine bay. Any idea what the official name for these fuses is? Also, I have a random cable that isn't hooked up to anything that has a boot on the end, ignition cable maybe? The ignition cable connector's plastic end is broken as well. Any input is helpful, I'll answer questions as best as I can
If you did everything properly it should not be an issue pics also help alot i should know i just took my engine out just for a timing belt and for fun and the box your talking about beside the main engine fuse box i think is a relay control box if im not mistaken
Nine-Breaker
Aug 28, 2012 11:53 AM
tweakdsm
16
Nov 10, 2009 07:15 PM
