4B11 Valve Clearance Adjustment
Old Nov 2, 2015 | 06:53 AM
tripletaco's Avatar
Forgive me if this info is poster somewhere but I havent been able to find it.
This pertains to my 2010 Lancer ES 2.0L I see that per Mitsubishi's recommended service, a valve clearance check/adjustment is suggested at 60k mi intervals. Ive seen very little info on the web about anyone actually doing this. What is the general consensus? Are this checks more a precautionary "recommendation" from Mitsubishi or does the 4B11 engine commonly need to have it's shims/buckets adjusted throughout its service life?
With that said, I went ahead and checked clearances on my 2010 Lancer ES this past weekend. The car has 95k mi on it, so Ive already waited way longer then Mitsu's suggested 60k mi interval. I found all valves to be with in specification except for 2 intake valves. The target clearance as i understand it is .008" +/- .0012". That puts the minimum clearance at .0068". On the 2 tight intake valves, i was able to get a .006" feeler in but not a .0065". All the other valves were within spec, but most were at the low limit.
Should i dig into this an make the necessary adjustments? How difficult are the shim/buckets to get? Is the typical dealer going to stock them?
Thanks in advance
Bandu1
Lancer Engine Tech
Oct 6, 2017 12:44 PM
3bar_dc2
Feb 28, 2016 11:30 AM
sirchumpalot
12
Feb 27, 2013 06:51 PM
Fizz Autosports
EvoX 'For Sale' Wheels / Tires
25
Mar 11, 2009 09:48 AM
zmeli
May 20, 2006 01:53 AM
Quick Reply: 4B11 Valve Clearance Adjustment
