magnacore wires
Old Sep 25, 2002 | 12:19 PM
PhillyLancer's Avatar
magnacore wires
wouldnt magnacore wires make just 2 engine cylinders fire better instead of all 4??? wouldnt you have to change the coil pack to get more spark in the other 2 cylinders??? just wonderin...any info would be greatly appreciated
Old Sep 25, 2002 | 12:24 PM
pjal84's Avatar
You can't really improve on the twin direct ignition system on cylinders 2 and 4 since they're fired directly from the coil. The reason why the Magnecor kit only replaces two wires that feed to the 1 and 3 cylinder is simply because those would be the weak parts of the ignition system that can be swapped with ease. Designing, developing, and manufacturing entirely new coils would be expensive.
Old Sep 26, 2002 | 09:07 AM
Joseanevo's Avatar
That is call waste spark energy , but here in P.R. we change them for Eclipse 2.4 Coil Packs (2 coils like OEM )
Old Sep 26, 2002 | 09:34 AM
bahamut's Avatar
The 3g coil pack is exactly the same as the 1.8L and the Lancer's motor. There is no reason for mitsu to design different coil pack systems, not cost effective.
Old Sep 27, 2002 | 08:17 AM
Joseanevo's Avatar
Don't know that but it works , also i have1.8 Magnecor wires in my ride
steven121
Lancer Aftermarket Forced Induction Tech
12
Apr 1, 2011 10:47 PM
mitsuozboi
Lancer Engine Tech
22
Aug 28, 2007 08:37 AM
ttmanta05
Mar 3, 2006 05:01 PM
EVOLVEU
12
Jan 23, 2006 02:58 PM
gregivq
Apr 5, 2005 04:20 PM
