02 sensors help
Unfortunately I don't know which color is which, however on the front O2 it's on terminal 1 and terminal 3, and at approx. 68F you should read the 4.5-8 ohms. On the rear it's terminal 3 and terminal 4 and at the same temperature you should get the 11-18 ohms. If you have a voltmeter you can figure out which pin is which fairly easy by checking for continuity by touching one pin with one lead from the voltmeter then moving the other lead across all the other pins until you find the two that work together.
K
K
i fixed the 02 problem BUT the sds is still off ! im playing with the idea of building a monster motor and then put the sds back on ! now my ques !!!! does any one know whare to get motor parts as far as a block and killer crank and a head i can port the hell out of ! i want to try to push close to 400 hp outa this car ! my 63 nova was dynoed at 720 big block and a 300 shot of juice put in into a 9.20 et my goal is to have THE FASTEST LANCER AROUND ! no offence guys i dont want to **** any one off so if anyone can help with these parts it would be a great help ! thanks in advance guys !
No one makes a crank yet. Crower would probably do it with specs or a donor to work from, but it'd probably be expensive. Basically sounds to me like you'd want to buy a spare motor to build outside the car. Try junkyards, online wreckers, motor shops, and ebay. They come up every now and then.
