t-28 turbo from rrm
t-28 turbo from rrm
Hacker / Tweeker Turbo Starter Kit
New T-28 turbo, heat wrapped up pipe and down pipe, TIAL 35mm external wastegate, oil supply(braided steel) and return line and all fittings,heat sleeve, wastegate dump tube,gaskets, and hardware. This is a great start to either non intercooled or intercooled turbo setup or for guys that want to do custom piping etc...
1899.00
I am seriously considering getting this... i know it dosent com with the intercooler, but i was wondering if anyone knew how much this tweeker set pushes out in whp added on to the stock and torque if anyone knows. Does anyone know if it comes with a bov too... and if i need anything else. Believe me if i could afford the full kit i would buy that but im not that rich... lol thanks for everything.
1899.00
It puts out exactly 0 extra HP.
That is a kit of items that you'd need to start a turbo kit. You'll need things like the FMU, the turbo piping, the SPAL fan, the Walbro fuel pump, the spark plugs, etc.
You're probably going to end up spending around $2500 to get a working kit (so you'd save some money over buying the $3k kit from RRM). Trust me on this, I started putting a kit together myself, thinking that I would buy the Hacker/Tweeker kit, so I know.
thats an idea i could use a t66 as a cooling fan! Better yet put a filter directly on the turbo and vent to intake side to the under part of the car and suck the hot air out.
