need ideas for new mods
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
i just ran into a brain-freeze on what to do next to my lancer. what do you guys think i should do next as a performance mod? at the moment i can't afford a turbo. here is a list of my mods and a link to my ride if you want to check it out:
Current Mods:
- AEM CAI
- 2.5inch Cat Back
- NGK Iridium IV plugs
- Clutchmasters Flywheel
- RRM Limited Slip Differential
- RRM Stage II Clutch
- RRM/Split Second Piggyback ECU
- RRM 4-1 Header
- Custom Downpipe
- Apex'I N-1 Muffler
- Ground Control Coil Overs
- Porterfield RS-4 Pads
- Centric Slotted Discs
- RRM K-Bar
- B & M Short Throw
https://www.evolutionm.net/registry/...e.php?vid=3450
i really can't decide what to do next. would upgrading the fuel system and delivery components help me gain more power? can somebody please help me out
Current Mods:
- AEM CAI
- 2.5inch Cat Back
- RRM 4-1 Header
- Custom Downpipe
- RRM K-Bar
- B & M Short Throw
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
Originally Posted by SLVROZ_03
RPW cam, cam gear, high-flow cat, etc. All this go for an extra, oh...maybe 15-20hp. Depending on your ability to tune. Good luck though.
High flow cat, Intake Manifold, Throtal body, Fuel Rail.
That will prepare you for:
Injectors, Fuel Pressure Regulator, Fuel Pump, Wires, Plugs, MDS Ignition system.
With your current mods you will get the best gains from these. (best less then a supercharger or turbo)
Originally Posted by Jotun
4G93 IM... its cheap and a great mod...my .02
![Stick Out Tongue](https://www.evolutionm.net/forums/images/smilies/tongue.gif)
Originally Posted by ambystom01
Throttle body, intake manifold, bored fuel rail, sway bar, tie bar, rear strut bar, a set of real coilovers (tein or NEX), kartboy shifter bushings, take your pick really.
This always kills me because if you where to add up all of the mods you have it would probably be the same price as turbo. I would say just save your money for the turbocharger man. Oh btw how are thoes ground crontrol coilovers?
jsfour- not true. You spend the money on the turbo kit and then ask "hey, how can I make this even faster" and end up buying most of this stuff anyway. Don't lie- you know if you're intrested in a turbo, you're interested in performance and we all know there's no end in sight once you start modding ![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
I wouldn't cam this car, unless I also wanted to get a new fuel management computer. And that's gonna be pricey. I just spent $300 on a WBO2 for my eManage and now I'm seeing that the ECU learns around piggybacks. So I had to spend another $60 to fool the ECU into thinking everything the eM tells it is ok. The support tool to even use these extra harnesses was another $40 (if you can find anyone who makes these anymore). Thank god the laptop was a freebie.
What I'm gettign at is the RRM piggy isn't tuned for the extras that a new cam is going to bring. From what I understand the RRM unit is pretty much as close to the edge as ou can safely get. cams will add a serious unknown into the mix.
TB and IM (G93 or G94) are your best bet for speed. Tein coilovers would be a great addition since with the SS kit you can adjust the dampening, and the basics are going to at least be stiffer than the stock dampers with the gc coilovers. What about some good competition tires (the new Falken Azenis 615s are supposed to be spectacular)?
You still have lots of options.
^^^ Tie bars make the rear end squirrley with a proper coilover setup. I had nothing but trouble and so did Urbanknight. He actually autocrossed with his bar, but I took mine off after some regular street driving (can't have that *** walking out on you during a turn on a regular city street- not good!)
