View Poll Results: Make them or not?
YES
41
91.11%
NO
8.89%
Voters: 45. You may not vote on this poll
Phenolic Spacers
#31
Originally Posted by smokin_oz03
count me in! excellent complement to a new 4g93 IM!
#33
Originally Posted by GreenPsycho
yeah, i think thats def. a great idea packing them together, cause they are both kinda small, it'd be a waste to sell and ship one without the other
I'm seriously checking into it guys. Once i get some pricing estimates and run quantity summations i'll let you know.
Keep the inputs coming... and start saving some cash as you just never know what product may come out soon.
#36
^the ones the one of the vendors were selling for the evo, came with 2 gaskets one for each side as well as longer bolts, but that was for the evo, i dont see why it would be different
#37
This is something i'm trying to incorportate into the design... that way there is no need for the gaskets. If i need to then i'll see how that effects pricing. For now though they are not planned on being needed. As long as the phenolic is made with a sealable surface there should be no issues. To test this i'm basically mounting a manifold to an aluminum piece of stock like it would be to the head. Then i'm putting one in between the tb. The aluminum stock is solid for sealing. Then i'm pressure testing the assembly. I figure if it can hold 25-30psi we're good to go.
Trust me it will be tried and trued before put on a shelf for sale... that's a promise!!
#40
i don't think sealing would be a problem, as long as they are machined so each exposed surface is flat (which is a guarantee cause i believe boe is doing this on the cnc mill)
hell, there are gaskets made out of soft aluminum, i figure this thermo-plastic material would have almost the same give so it would be perfect for sealing like a gasket
#41
Yeah I'd totally be down for the set, too. Except I have no idea in f.ck how to put them on. But several people on here are helpful and I usually just search and read to figure sh.t out.
#43
hardest one would be the IM one, and that should be easy enough since you aren't swapping out the IM, just taking it off a little bit, swap gaskets, and bolt it back up
with all you guys doing IM and bored TB swaps, i'd say spend the extra 100 bucks or less (whatever boe decides to charge) and pick these up at the same time. 2 birds, 1 stone and some nice gains
#44
would this spacer also work with the 4g93 manifold. I'm considering getting that and having it ported since everyone tends to agree I'd see better gains from that than a ported 4g94.
Also a little off topic but does anyone know of a thread/ how to for removing/ installing the intake manifold. I didnt' search but I figured I might as well ask since we're on the general subject and it seems many of you have already done this.
#45
yes, will fit 4g93, its the same bolt pattern adn uses same gaskets
for install, there are 3 threads floating around on manifold installs, you dont' even need to search, they were bumped to the top of a few forums (lancer gen, lancer engine, how to/install i think)
