Worth $100, or not...ebay electric turbo
Originally Posted by GreenPsycho
remember guys, it means taking off and replacing both belts, so you have to deal with the serpentine tensioner and the tensioner on the alternator, which means getting underneath the car (duh) so you'll need some ramps or stands for this one
ROAD///RACE Light Aluminum Crank Pulley
NEW for 02-05 Lancers- 4G94 engines.
This is a custom ROAD/RACE CNC machined crank pulley. It is made of aircraft grade aluminum and weighs just 1 lb. Stock pulley weighs more than 4 lbs. and robs h.p. from the engine to spin it. Just like a light flywheel, throttle response will be greatly improved!Installs in minutes and uses original belts.
Originally Posted by Kid Lancer 7
who is acutally running with the rrm pulley?? how does it feel?? any noticable gain??
Green the tensionors for the belts are really easy. all u need is like a 12 or 14mm rachet. the bolts for the tensioners are easily accessible under the hood.
1 Post
well, two things: uses original belts as in uses the original SIZED belts, inferring its not an underdrive.
but i meant "replace" as in take belt off, put new pulley on, re-place old belt back on pulley
hell, as long as you have the belts off, if there are a little worn, might as well replace 'em
edit:
you didn't do the install, did ya? there is no way you could reach the alternator tensioner from the hood, you have to go under, same with looping the belts. i can't speak for the tensioner cause ripp relocated mine, so its in a slightly different spot than your guys', but still
look i'm not trying to make this sound impossible, I just want people to realize its not a simple lunch break install like an intake or something. this is going to take some tools, some ramps (or stands) and some know how. thats it
edit:
i thank you for the advice.
right now, I have header, downpipe, and cold air. so from that, pulley or TB?
...since everything works together, what can I expect the best throttle response and HP gains?
I'd say you've already improved heavily on your cars breathing... Getting a catback would help your midrange power a bit more, maybe 2-5whp. The pulley will give you good gains from the low end and help to eliminate some powerloss, maybe 5whp from best estimates. I'd finish off your I/H/E setup and get a catback eventually... but for the money I'd say get the pully...
Fox
Fox
edit:
edit:
Marco M. Duarte
lancer0220
Jan 14, 2010 09:34 PM
